Einleitung
How many times have you had to throw your eyeliner pen in the trash because it dried out? Well, here is a solution for you that will not only provide you with a new eyeliner pen but will also save you money. Here is a guide on How to Rehydrate a Dried Eyeliner Pen using items that you already have in your house.
Note that this fix can get messy, so if there is a concern about your skin being irritated I recommend using latex gloves.
Was du brauchst
Before you start, test out your dried eyeliner pen so you can compare the results at the end!
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Remove the cap from your eyeliner pen.
Take a small pair of pliers and gently remove the felt rod from inside the liner.
Once the felt rod has been removed, gently place the rod in a bowl of warm water for no more than 30 seconds.
Take the felt rod out of the water and immediately place it on a paper towel.
Gently pat the felt rod dry using a paper towel.
