Einleitung
The purpose of this guide is to show the process of how to remove the rust off of a gardening shovel.
When a metal shovel is left outside in the elements for too long, it has the potential to become rusted over. When this happens, you are able to remove this rust at home using household items.
Though this is a simple process that can be done at home, it can be lengthy and require a moderate amount of effort to physically remove the rust depending on the level of tarnish.
Was du brauchst
Scrub the shovel with a scrub brush.
Scrub with a tooth brush.
Scrub with a Brillo pad.
Repeat process until rust is completely removed.
