Zum Hauptinhalt wechseln
How to Remove Rust on Car Body
Was du brauchst
  1. How to Remove Rust on Car Body, How to Remove Rust on Car Body: Schritt 1, Bild 1 von 2 How to Remove Rust on Car Body, How to Remove Rust on Car Body: Schritt 1, Bild 2 von 2
    • Spray down the rust with a spray bottle mixed with water and dish soap.
    • Wipe the mixture with a microfiber cloth.
  2. How to Remove Rust on Car Body: Schritt 2, Bild 1 von 3 How to Remove Rust on Car Body: Schritt 2, Bild 2 von 3 How to Remove Rust on Car Body: Schritt 2, Bild 3 von 3
    • Pour a small amount of rubbing alcohol onto a microfiber cloth.
    • Clean the rusted area with the cloth to remove any contaminants.
  3. How to Remove Rust on Car Body: Schritt 3, Bild 1 von 3 How to Remove Rust on Car Body: Schritt 3, Bild 2 von 3 How to Remove Rust on Car Body: Schritt 3, Bild 3 von 3
    • Rub the rusted area with 80-grit sandpaper until you start seeing the bare metal.
  4. How to Remove Rust on Car Body: Schritt 4, Bild 1 von 2 How to Remove Rust on Car Body: Schritt 4, Bild 2 von 2
    • Rub the rusted area with 220-grit sandpaper until all of the rust is removed.
    • Dampen a cloth with soapy water and wipe down the sanded area.
  5. How to Remove Rust on Car Body: Schritt 5, Bild 1 von 2 How to Remove Rust on Car Body: Schritt 5, Bild 2 von 2
    • This step is to prepare your spot for spray painting.
    • Add some paper around the areas you do not want paint on. Make sure you go a little past where you are going to spray paint to blend the paint into the surrounding area.
  6. How to Remove Rust on Car Body: Schritt 6, Bild 1 von 3 How to Remove Rust on Car Body: Schritt 6, Bild 2 von 3 How to Remove Rust on Car Body: Schritt 6, Bild 3 von 3
    • Spray three even coats of primer, waiting at least five minutes between each coat.
    • Let the third coat sit for 15 minutes.
  7. How to Remove Rust on Car Body: Schritt 7, Bild 1 von 3 How to Remove Rust on Car Body: Schritt 7, Bild 2 von 3 How to Remove Rust on Car Body: Schritt 7, Bild 3 von 3
    • Spray three even coats of paint on top of the primer, waiting five minutes between each coat.
    • You can either use a color similar to your car or you can get the actual color of you car by looking for the car's color code.
    • After the final coat, wait 24 hours before removing the surrounding paper.
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
CSU Los Angeles, Team 10-20, Briggs Fall 2022 Mitglied von CSU Los Angeles, Team 10-20, Briggs Fall 2022
CSULA-BRIGGS-F22S10G20
1 Mitglied
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 24
Letzte 30 Tage: 122
Insgesamt: 1,807
