Zum Hauptinhalt wechseln
How to Remove a Broken and Embedded Screw
Was du brauchst
  1. How to Remove a Broken and Embedded Screw, How to Remove a Broken and Embedded Screw: Schritt 1, Bild 1 von 1
    • Use an angle grinder to grind the tip of the broken screw until its surface is smooth and even.
  2. How to Remove a Broken and Embedded Screw: Schritt 2, Bild 1 von 2 How to Remove a Broken and Embedded Screw: Schritt 2, Bild 2 von 2
    • Place a center punch in the middle of the tip of the screw.
    • Use a hammer to hit the center punch to make a dent in the center of the embedded screw.
  3. How to Remove a Broken and Embedded Screw: Schritt 3, Bild 1 von 3 How to Remove a Broken and Embedded Screw: Schritt 3, Bild 2 von 3 How to Remove a Broken and Embedded Screw: Schritt 3, Bild 3 von 3
    • Place a center drill bit in the dent made in the previous step and start drilling until it expands enough to fit the standard drill bit inside it.
    • Always keep the drill bit at a 90 degree angle to the surface of the screw since tilting it can bend and break its tip.
  4. How to Remove a Broken and Embedded Screw: Schritt 4, Bild 1 von 3 How to Remove a Broken and Embedded Screw: Schritt 4, Bild 2 von 3 How to Remove a Broken and Embedded Screw: Schritt 4, Bild 3 von 3
    • Make a hole in the tip of the screw by drilling with a standard drill bit.
    • Keep drilling until the hole reaches near the end of the screw.
  5. How to Remove a Broken and Embedded Screw: Schritt 5, Bild 1 von 2 How to Remove a Broken and Embedded Screw: Schritt 5, Bild 2 von 2
    • Insert a screw extractor in the hole and then hammer it inside, making sure it is tight.
  6. How to Remove a Broken and Embedded Screw: Schritt 6, Bild 1 von 3 How to Remove a Broken and Embedded Screw: Schritt 6, Bild 2 von 3 How to Remove a Broken and Embedded Screw: Schritt 6, Bild 3 von 3
    • Using a wrench, unscrew the extractor.
    • The screw will come along with it, freeing the hole.
  7. How to Remove a Broken and Embedded Screw: Schritt 7, Bild 1 von 2 How to Remove a Broken and Embedded Screw: Schritt 7, Bild 2 von 2
    • Screw the new screw inside the freed hole.
Ziellinie
3 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 22
Letzte 7 Tage: 107
Letzte 30 Tage: 489
Insgesamt: 6,808
