Zum Hauptinhalt wechseln
How to Repair a Ceramic Mug
Was du brauchst
  1. How to Repair a Ceramic Mug, How to Repair a Ceramic Mug: Schritt 1, Bild 1 von 3 How to Repair a Ceramic Mug, How to Repair a Ceramic Mug: Schritt 1, Bild 2 von 3 How to Repair a Ceramic Mug, How to Repair a Ceramic Mug: Schritt 1, Bild 3 von 3
    • Avoid any sharp edges while handling your cup to avoid injury.
    • Take a piece of the mug and carefully apply the silicone adhesive along the broken edge.
  2. How to Repair a Ceramic Mug: Schritt 2, Bild 1 von 3 How to Repair a Ceramic Mug: Schritt 2, Bild 2 von 3 How to Repair a Ceramic Mug: Schritt 2, Bild 3 von 3
    • Align the edges and press firmly to join the pieces.
  3. How to Repair a Ceramic Mug: Schritt 3, Bild 1 von 2 How to Repair a Ceramic Mug: Schritt 3, Bild 2 von 2
    • Wipe off any excess adhesive with your towel.
    • Stubborn adhesive can also be removed after curing (Refer to Step 6).
  4. How to Repair a Ceramic Mug: Schritt 4, Bild 1 von 3 How to Repair a Ceramic Mug: Schritt 4, Bild 2 von 3 How to Repair a Ceramic Mug: Schritt 4, Bild 3 von 3
    • Wrap the mug with a towel to secure the repair while drying.
  5. How to Repair a Ceramic Mug: Schritt 5, Bild 1 von 2 How to Repair a Ceramic Mug: Schritt 5, Bild 2 von 2
    • Wait 24 hours for the silicone to cure fully.
  6. How to Repair a Ceramic Mug: Schritt 6, Bild 1 von 3 How to Repair a Ceramic Mug: Schritt 6, Bild 2 von 3 How to Repair a Ceramic Mug: Schritt 6, Bild 3 von 3
    • Always use caution when handling sharp tools.
    • Trim any dried excess adhesive using an X-Acto knife.
Abschluss
After about 24 hours your mug should be fully cured and ready to be used for decorative purposes!
Crystal Yeung
133 Reputation
1 Anleitung geschrieben
UC Davis, Team 4-7, Andersen Winter 2023 Mitglied von UC Davis, Team 4-7, Andersen Winter 2023
UCD-ANDERSEN-W23S4G7
3 Mitglieder
2 Anleitungen geschrieben
Ein Kommentar
Dap 00688 All-Purpose Adhesive Sealant is safe for food contact and has a high operating temperature. Shouldn't this be safe to use as drinkware?
Glacial - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 19
Letzte 30 Tage: 121
Insgesamt: 1,803
