Zum Hauptinhalt wechseln
How to Repair a Hole in Workout/Yoga Around the Groin
Was du brauchst
  1. How to Repair a Hole in Workout/Yoga Around the Groin, How to Repair a Hole in Workout/Yoga Around the Groin: Schritt 1, Bild 1 von 1
    • Take the pants and put them inside out.
    • You want the seams to be showing.
  2. How to Repair a Hole in Workout/Yoga Around the Groin: Schritt 2, Bild 1 von 1
    • Take the sewing pins (if the hole is big) and pin closed along the seam.
    • This should take no more than 5 pins to do.
  3. How to Repair a Hole in Workout/Yoga Around the Groin: Schritt 3, Bild 1 von 3 How to Repair a Hole in Workout/Yoga Around the Groin: Schritt 3, Bild 2 von 3 How to Repair a Hole in Workout/Yoga Around the Groin: Schritt 3, Bild 3 von 3
    • Take the thread (make sure it is the preferred color that matches the pants) and thread it through the needle.
    • Make sure to leave a large tail at least 20 inches.
    • Tie the two ends together into a small knot.
  4. How to Repair a Hole in Workout/Yoga Around the Groin: Schritt 4, Bild 1 von 1
    • Insert the needle into the fabric from one side until you can see the needle on the other side.
    • Pull all the way through.
  5. How to Repair a Hole in Workout/Yoga Around the Groin: Schritt 5, Bild 1 von 1
    • Take the needle and put it back through the fabric a short distance from where it came out originally.
  6. How to Repair a Hole in Workout/Yoga Around the Groin: Schritt 6, Bild 1 von 1
    • Continue steps 7 and 8 until you have reached the other end of the hole.
  7. How to Repair a Hole in Workout/Yoga Around the Groin: Schritt 7, Bild 1 von 2 How to Repair a Hole in Workout/Yoga Around the Groin: Schritt 7, Bild 2 von 2
    • Once you have finished sewing the hole, take the thread and tie a small knot at the base of the thread.
    • Cut thread and reverse the pants to check the seam.
  8. How to Repair a Hole in Workout/Yoga Around the Groin: Schritt 8, Bild 1 von 1
    • If seam is completely closed, then you have done it!
    • If not, then repeat steps 7-11 until hole is completely closed.
Abschluss
If seam is completely closed, then you have done it! If not, then repeat steps 7-11 until hole is completely closed.
Jessy Sternblitz
157 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 23
Insgesamt: 103
