Zum Hauptinhalt wechseln
How to Repair a Jammed 2007 GMC Envoy Tailgate
Was du brauchst
  1. How to Repair a Jammed 2007 GMC Envoy Tailgate, Tailgate Latch Bracket: Schritt 1, Bild 1 von 3 How to Repair a Jammed 2007 GMC Envoy Tailgate, Tailgate Latch Bracket: Schritt 1, Bild 2 von 3 How to Repair a Jammed 2007 GMC Envoy Tailgate, Tailgate Latch Bracket: Schritt 1, Bild 3 von 3
    • Use the flat head screwdriver to pry off the small round access panel on the interior of the tailgate.
  2. How to Repair a Jammed 2007 GMC Envoy Tailgate: Schritt 2, Bild 1 von 2 How to Repair a Jammed 2007 GMC Envoy Tailgate: Schritt 2, Bild 2 von 2
    • Look through the opening and stick your flat head screwdriver underneath this metal arm.
    • Force the arm up. It should stay raised when you pull the screwdriver out.
    • DO NOT USE YOUR FINGER, there is risk of pinching and injury if you do not use the specified tools.
  3. How to Repair a Jammed 2007 GMC Envoy Tailgate: Schritt 3, Bild 1 von 3 How to Repair a Jammed 2007 GMC Envoy Tailgate: Schritt 3, Bild 2 von 3 How to Repair a Jammed 2007 GMC Envoy Tailgate: Schritt 3, Bild 3 von 3
    • Use the flat head screwdriver to push this second lever to the right as far as it will go or until it clicks.
  4. How to Repair a Jammed 2007 GMC Envoy Tailgate: Schritt 4, Bild 1 von 2 How to Repair a Jammed 2007 GMC Envoy Tailgate: Schritt 4, Bild 2 von 2
    • The tailgate is now unlatched. Open it from the outside.
    • Replace the access panel.
    • If the tailgate will still not open, you most likely did not push the second lever over far enough. Repeat Step 3.
  5. How to Repair a Jammed 2007 GMC Envoy Tailgate: Schritt 5, Bild 1 von 2 How to Repair a Jammed 2007 GMC Envoy Tailgate: Schritt 5, Bild 2 von 2
    • Inspect the latch bracket's horizontal and vertical bars for dents, warping, and corrosion.
    • If there are no physical defects visible, clean any rust and corrosion and test the tailgate. If it still jams, repeat Steps 1-4 and move on to Step 6.
  6. How to Repair a Jammed 2007 GMC Envoy Tailgate: Schritt 6, Bild 1 von 1
    • Use the 40 Torx screwdriver to remove the two T40 63.5 mm screws that secure the latch bracket.
    • Remove the latch from the vehicle.
Abschluss
To reassemble your device, follow these steps in reverse order.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 56
Insgesamt: 3,609
