Zum Hauptinhalt wechseln
How to Repair a Round Head Ratchet
Was du brauchst
  1. How to Repair a Round Head Ratchet, How to Repair a Round Head Ratchet: Schritt 1, Bild 1 von 3 How to Repair a Round Head Ratchet, How to Repair a Round Head Ratchet: Schritt 1, Bild 2 von 3 How to Repair a Round Head Ratchet, How to Repair a Round Head Ratchet: Schritt 1, Bild 3 von 3
    • Remove the direction selector dial by turning it counterclockwise with a T15 screwdriver.
  2. How to Repair a Round Head Ratchet: Schritt 2, Bild 1 von 3 How to Repair a Round Head Ratchet: Schritt 2, Bild 2 von 3 How to Repair a Round Head Ratchet: Schritt 2, Bild 3 von 3
    • Lift up on the direction selector dial to remove it.
    • Be careful to keep the heart spring in place during removal.
  3. How to Repair a Round Head Ratchet: Schritt 3, Bild 1 von 3 How to Repair a Round Head Ratchet: Schritt 3, Bild 2 von 3 How to Repair a Round Head Ratchet: Schritt 3, Bild 3 von 3
    • Lift up on the heart spring to remove it.
  4. How to Repair a Round Head Ratchet: Schritt 4, Bild 1 von 3 How to Repair a Round Head Ratchet: Schritt 4, Bild 2 von 3 How to Repair a Round Head Ratchet: Schritt 4, Bild 3 von 3
    • Remove the pawl and anvil by sliding them out of the ratchet handle.
  5. How to Repair a Round Head Ratchet: Schritt 5, Bild 1 von 1
    • Clean all the old grease and dirt off the parts with a rag.
  6. How to Repair a Round Head Ratchet: Schritt 6, Bild 1 von 2 How to Repair a Round Head Ratchet: Schritt 6, Bild 2 von 2
    • Lubricate the pawl and the teeth in the head of the ratchet handle with a light coat of multi-purpose grease.
  7. How to Repair a Round Head Ratchet: Schritt 7, Bild 1 von 3 How to Repair a Round Head Ratchet: Schritt 7, Bild 2 von 3 How to Repair a Round Head Ratchet: Schritt 7, Bild 3 von 3
    • Reinstall the anvil and pawl by sliding them into the ratchet handle.
  8. How to Repair a Round Head Ratchet: Schritt 8, Bild 1 von 3 How to Repair a Round Head Ratchet: Schritt 8, Bild 2 von 3 How to Repair a Round Head Ratchet: Schritt 8, Bild 3 von 3
    • Reinstall the heart spring by sliding the end of the spring into the hole in the pawl.
  9. How to Repair a Round Head Ratchet: Schritt 9, Bild 1 von 3 How to Repair a Round Head Ratchet: Schritt 9, Bild 2 von 3 How to Repair a Round Head Ratchet: Schritt 9, Bild 3 von 3
    • Reinstall the direction selector dial, being careful to place the stud on the dial within the loop of the heart spring.
  10. How to Repair a Round Head Ratchet: Schritt 10, Bild 1 von 3 How to Repair a Round Head Ratchet: Schritt 10, Bild 2 von 3 How to Repair a Round Head Ratchet: Schritt 10, Bild 3 von 3
    • Reinstall the direction selector dial screw and tighten in a clockwise direction with a T15 screwdriver.
Ziellinie
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Lucas
229 Reputation
1 Anleitung geschrieben
University of Memphis, Team 51-2, Willis Fall 2021 Mitglied von University of Memphis, Team 51-2, Willis Fall 2021
UM-WILLIS-F21S51G2
1 Mitglied
3 Anleitungen geschrieben
2 Kommentare
Very clear and accurate, especially for the spring shape and its positioning in installation, which helped me to fix the problem with it.
Jason Zou - Antwort
Perfect pictures and descriptions! My wrench is working again! Thanks!!!
John B. - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 9
Letzte 7 Tage: 57
Letzte 30 Tage: 235
Insgesamt: 4,138
