Einleitung
Over time, our favorite pairs of shoes can begin to decline with wear, and the sole may loosen or come apart. Whether your rubber heel is torn or your sole is separating from the bottom of your shoe, our guide can help you continue to wear your favorite shoes.
Was du brauchst
Use sanitizing wipes to clean any debris in the tear of the sole.
Carefully pull the sole away from the shoe, making sure not to widen the tear or cause excessive deformation.
Apply enough glue in the space so that an even layer is able to form between the shoe and sole when pressed together. Make sure to apply some along the inside seam.
Use rubber bands to secure the sole to the shoe while it dries. This will ensure a firm seal.
Enjoy the newfound longevity of your shoe!
2 weitere Nutzer:innen haben diese Anleitung absolviert.
