Zum Hauptinhalt wechseln
How to Replace Cracked Tile
Was du brauchst
  1. How to Replace Cracked Tile, Cracked Tile: Schritt 1, Bild 1 von 1
    • Use a painter's tool or putty knife to remove the grout from around the cracked tile.
    • Using an edge or corner of your painter's tool or putty knife, scrape the grout along the perimeter of the broken tile.
    • Be careful not to crack or scratch surrounding tiles.
  2. How to Replace Cracked Tile: Schritt 2, Bild 1 von 3 How to Replace Cracked Tile: Schritt 2, Bild 2 von 3 How to Replace Cracked Tile: Schritt 2, Bild 3 von 3
    • Use the painter's tool or putty knife to pry up the broken tile.
    • If the tile does not lift, place an old rag over the tile and use the hammer to break the tile into smaller pieces.
    • Avoid using surrounding tile as leverage and be precise and careful while using the hammer.
  3. How to Replace Cracked Tile: Schritt 3, Bild 1 von 3 How to Replace Cracked Tile: Schritt 3, Bild 2 von 3 How to Replace Cracked Tile: Schritt 3, Bild 3 von 3
    • Remove the broken pieces of tile, using gloved hands for large pieces or a broom for smaller shards.
    • Using the painter's tool or putty knife, scrape the grout from the edges of tile and any adhesive from under the tile.
    • Be careful of sharp shards of tile.
  4. How to Replace Cracked Tile: Schritt 4, Bild 1 von 3 How to Replace Cracked Tile: Schritt 4, Bild 2 von 3 How to Replace Cracked Tile: Schritt 4, Bild 3 von 3
    • Apply new adhesive using the trowel, making sure the adhesive is spread evenly.
    • Drag the toothed end of the trowel across the adhesive to create even rows.
    • Quickly remove any adhesive from the surrounding tiles using a wet sponge or old rag, working quickly as the adhesive will begin to dry.
  5. How to Replace Cracked Tile: Schritt 5, Bild 1 von 3 How to Replace Cracked Tile: Schritt 5, Bild 2 von 3 How to Replace Cracked Tile: Schritt 5, Bild 3 von 3
    • Place the new tile down in the center of the empty space.
    • If available, use tile spacers to ensure proper placement.
    • Allow the adhesive to dry based on the instructions provided on the product.
    • During this time, prevent foot traffic on the new tile.
  6. How to Replace Cracked Tile: Schritt 6, Bild 1 von 2 How to Replace Cracked Tile: Schritt 6, Bild 2 von 2
    • After the adhesive has dried, add water to a small amount of grout until it's the consistency of toothpaste.
    • Fill in the area around the new tile, making sure the new grout matches the height of the surrounding grout.
    • Use a moist sponge to wipe diagonally across the tile, cleaning off excess grout after each wipe.
  7. How to Replace Cracked Tile: Schritt 7, Bild 1 von 2 How to Replace Cracked Tile: Schritt 7, Bild 2 von 2
    • If any bubbles or gaps form in the grout while removing excess, add more grout and repeat the cleaning process.
    • Wait and allow grout to dry for several hours.
    • Keep foot traffic away from the new tile until the grout has had time to dry.
Abschluss
Allow the grout to dry and then resume normal use.
8 weitere Nutzer:innen haben diese Anleitung absolviert.
Texas Tech, Team 26-7, Rauch Spring 2016 Mitglied von Texas Tech, Team 26-7, Rauch Spring 2016
TTU-RAUCH-S16S26G7
3 Mitglieder
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 17
Letzte 30 Tage: 56
Insgesamt: 3,984
