Einleitung
Need to remove or replace an old cabinet door? Here's an easy step by step guide on removing and replacing a cabinet door using only a screwdriver.
Was du brauchst
Using a screwdriver, either a Flathead or a Phillips, remove the screws starting from the bottom of the door all the way to the top of the door to prevent the door from swinging.
Place the new cabinet on a flat surface. Then line up the old (or new) hinge's to holes on the door.
Finally, line up the hinge’s holes with the holes from the previous cabinet door. Then screw the new door on.
To reassemble your cabinet, follow these instructions in reverse order.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
