Zum Hauptinhalt wechseln
How to Replace a Valve Spring on a Trumpet
Was du brauchst
  1. How to Replace a Valve Spring on a Trumpet, valve spring: Schritt 1, Bild 1 von 2 How to Replace a Valve Spring on a Trumpet, valve spring: Schritt 1, Bild 2 von 2
    • To pull out the valve, first twist the top of the valve open counterclockwise to detach it from the rest of the valve.
    • Pull the valve out of the trumpet.
  2. How to Replace a Valve Spring on a Trumpet: Schritt 2, Bild 1 von 2 How to Replace a Valve Spring on a Trumpet: Schritt 2, Bild 2 von 2
    • Near the top of the valve, twist the top part of the screw compartment off to access the screw.
    • Pull the old spring out and replace with the new one.
    • Reassemble the valve the same way it came apart.
  3. How to Replace a Valve Spring on a Trumpet: Schritt 3, Bild 1 von 2 How to Replace a Valve Spring on a Trumpet: Schritt 3, Bild 2 von 2
    • Before inserting the valve back into the trumpet, put enough valve oil on the valve so that that the surface is wet, but not dripping.
    • Insert the valve into the trumpet, and screw in the top clockwise.
    • Be sure to grasp the top of the valve and twist until a clicking sound is heard and the valve locks in place to ensure that the trumpet is ready for playing.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Cal Poly, Team 23-4, Green Winter 2015 Mitglied von Cal Poly, Team 23-4, Green Winter 2015
CPSU-GREEN-W15S23G4
7 Mitglieder
15 Anleitungen geschrieben
Ein Kommentar
I cannot manage to take out my valve it is so hard It’s a brand new trumpet sound like come out and then I don’t have valve oil
Flavio - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 42
Insgesamt: 8,221
