Zum Hauptinhalt wechseln
How to Replace the Handle on a KitchenArt Nonstick Pot
Was du brauchst
  1. How to Replace the Handle on a KitchenArt Nonstick Pot, How to Replace the Handle on a KitchenArt Nonstick Pot: Schritt 1, Bild 1 von 1
    • Clean the components.
  2. How to Replace the Handle on a KitchenArt Nonstick Pot: Schritt 2, Bild 1 von 3 How to Replace the Handle on a KitchenArt Nonstick Pot: Schritt 2, Bild 2 von 3 How to Replace the Handle on a KitchenArt Nonstick Pot: Schritt 2, Bild 3 von 3
    • Insert the screw through the center of the smaller steel bracket.
  3. How to Replace the Handle on a KitchenArt Nonstick Pot: Schritt 3, Bild 1 von 2 How to Replace the Handle on a KitchenArt Nonstick Pot: Schritt 3, Bild 2 von 2
    • Line up the pegs of the handle with the holes in the larger iron bracket.
  4. How to Replace the Handle on a KitchenArt Nonstick Pot: Schritt 4, Bild 1 von 3 How to Replace the Handle on a KitchenArt Nonstick Pot: Schritt 4, Bild 2 von 3 How to Replace the Handle on a KitchenArt Nonstick Pot: Schritt 4, Bild 3 von 3
    • Insert the screw with the smaller iron sheet from inside of the lid to outside of the lid
  5. How to Replace the Handle on a KitchenArt Nonstick Pot: Schritt 5, Bild 1 von 1
    • Insert the screw into the screw hole in the lid.
  6. How to Replace the Handle on a KitchenArt Nonstick Pot: Schritt 6, Bild 1 von 3 How to Replace the Handle on a KitchenArt Nonstick Pot: Schritt 6, Bild 2 von 3 How to Replace the Handle on a KitchenArt Nonstick Pot: Schritt 6, Bild 3 von 3
    • Slightly turn over the lid to make yourself face to inside of the lid
  7. How to Replace the Handle on a KitchenArt Nonstick Pot: Schritt 7, Bild 1 von 3 How to Replace the Handle on a KitchenArt Nonstick Pot: Schritt 7, Bild 2 von 3 How to Replace the Handle on a KitchenArt Nonstick Pot: Schritt 7, Bild 3 von 3
    • Use a screwdriver to tighten the screw.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Zijing Wang
169 Reputation
1 Anleitung geschrieben
York University, Team O-29, Woodhouse Winter 2023 Mitglied von York University, Team O-29, Woodhouse Winter 2023
YORK-WOODHOUSE-W23SOG29
2 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 31
Insgesamt: 248
