Zum Hauptinhalt wechseln
How to fix a Samsung Galaxy S5 that is not charging
Was du brauchst
  1. How to fix a Samsung Galaxy S5 that is not charging, Check Charging Port: Schritt 1, Bild 1 von 1
    • Note: Images here are from the internet for reference only but not from me
    • Check the charging port at the bottom of the phone. I used a magnifying glass with light to see because these are very small.
  2. How to fix a Samsung Galaxy S5 that is not charging, Check the pins: Schritt 2, Bild 1 von 1
    • When I checked the pins in my phone, I saw 3. with the one on the rightmost having 2 layers. This was because one of them was bent making it look like there were only 3 instead of 4
    • I used a needle to push the bent pin. After a few pushes, it started charging again!
    • Reminder: be very careful when pushing the pins. I only did this because my phone was not charging at all and I was ready to get a replacement for the charging port if it still didn't work
Abschluss
10 weitere Nutzer:innen haben diese Anleitung absolviert.
SLomat
360 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 58
Insgesamt: 6,139
