Einleitung
If your Ikea PLUTTIS Clock is low on battery, or slow and it needs a change. With the help of this guide, you can fix your Clock and get it back in working order by replacing the battery.
Was du brauchst
To place the battery properly locate the positive and negative indicators on your clock.
Using your fingers, insert the negative side of the battery into the back of the clock and push it in.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
