Zum Hauptinhalt wechseln
Installing Mercedes W166 RAV Tool Box
Was du brauchst
  1. Installing Mercedes W166 RAV Tool Box, RAV Tool Box: Schritt 1, Bild 1 von 2 Installing Mercedes W166 RAV Tool Box, RAV Tool Box: Schritt 1, Bild 2 von 2
    • 1. Vehicle Preparation
    • Remove all loose items from the cargo area. Remove the cargo floor, spare wheel and tool tray.
    • Remove rear seats as in WIS instructions (Save seat mounting hardware)
  2. Installing Mercedes W166 RAV Tool Box: Schritt 2, Bild 1 von 3 Installing Mercedes W166 RAV Tool Box: Schritt 2, Bild 2 von 3 Installing Mercedes W166 RAV Tool Box: Schritt 2, Bild 3 von 3
    • Remove bolt from rear deck sill plate
    • Unclip rear deck sill plate and remove.
  3. Installing Mercedes W166 RAV Tool Box: Schritt 3, Bild 1 von 1
    • Remove plastic covers
    • Remove Felt liner
  4. Installing Mercedes W166 RAV Tool Box: Schritt 4, Bild 1 von 3 Installing Mercedes W166 RAV Tool Box: Schritt 4, Bild 2 von 3 Installing Mercedes W166 RAV Tool Box: Schritt 4, Bild 3 von 3
    • Remove side consoles and center support (T30 10 Bolts)
  5. Installing Mercedes W166 RAV Tool Box: Schritt 5, Bild 1 von 3 Installing Mercedes W166 RAV Tool Box: Schritt 5, Bild 2 von 3 Installing Mercedes W166 RAV Tool Box: Schritt 5, Bild 3 von 3
    • Install and bolt down center support bracket (2 Bolts M10 x 1.5 x35mm 6mm Allen cap, 10mm flat washers)
    • Pay attention to the pin to align properly
    • NOTE: To service TPMS control module remove drawers ad service through access door in bottom plate.
  6. Installing Mercedes W166 RAV Tool Box: Schritt 6, Bild 1 von 3 Installing Mercedes W166 RAV Tool Box: Schritt 6, Bild 2 von 3 Installing Mercedes W166 RAV Tool Box: Schritt 6, Bild 3 von 3
    • 2. Installation of Front Box
    • Place box inside vehicle. It fits through the rear doors. This is a 2 person job.
    • Mount front legs on front consoles, tighten loosely (2 Bolts M10 x 1.5 x35mm 6mm Allen cap, 10mm flat washers). Pay attention not to break off the alignment pin, which will be inside the post after mounting.
    • DO NOT mount the box to the center bracket at this point
  7. Installing Mercedes W166 RAV Tool Box: Schritt 7, Bild 1 von 2 Installing Mercedes W166 RAV Tool Box: Schritt 7, Bild 2 von 2
    • 3. Installation of the rear plate
    • Install 6 rear support brackets and tighten finger tight
  8. Installing Mercedes W166 RAV Tool Box: Schritt 8, Bild 1 von 3 Installing Mercedes W166 RAV Tool Box: Schritt 8, Bild 2 von 3 Installing Mercedes W166 RAV Tool Box: Schritt 8, Bild 3 von 3
    • Set plate on brackets and align, overlapping the base plate of the front box on the center support bracket.
    • Use punch tool to align holes and drop in 2 bolts M8 x 1.25 x 40mm in holes on each side and one bolt M8 x 1.25 x 30 in the center hole.
  9. Installing Mercedes W166 RAV Tool Box: Schritt 9, Bild 1 von 3 Installing Mercedes W166 RAV Tool Box: Schritt 9, Bild 2 von 3 Installing Mercedes W166 RAV Tool Box: Schritt 9, Bild 3 von 3
    • Secure plate to center support bracket with 2 bolts on the outside and on in the middle, align and finger tighten
  10. Installing Mercedes W166 RAV Tool Box: Schritt 10, Bild 1 von 2 Installing Mercedes W166 RAV Tool Box: Schritt 10, Bild 2 von 2
    • Install 3 bolts securing base plate to vehicle frame
    • and 4th bolt securing the tool box rail to the base plate and vehicle frame.
    • Put bolt sizes in
  11. Installing Mercedes W166 RAV Tool Box: Schritt 11, Bild 1 von 2 Installing Mercedes W166 RAV Tool Box: Schritt 11, Bild 2 von 2
    • Install and loosely tighten 3 M8 black oxide bolts on each side until L bracket touches the underside of the base plate
  12. Installing Mercedes W166 RAV Tool Box: Schritt 12, Bild 1 von 2 Installing Mercedes W166 RAV Tool Box: Schritt 12, Bild 2 von 2
    • Fully tighten M8 (20 Nm)
    • Fully tighten M6 (8 Nm)
  13. Installing Mercedes W166 RAV Tool Box: Schritt 13, Bild 1 von 3 Installing Mercedes W166 RAV Tool Box: Schritt 13, Bild 2 von 3 Installing Mercedes W166 RAV Tool Box: Schritt 13, Bild 3 von 3
    • Fully tighten M10 bolts (35 Nm)
  14. Installing Mercedes W166 RAV Tool Box: Schritt 14, Bild 1 von 3 Installing Mercedes W166 RAV Tool Box: Schritt 14, Bild 2 von 3 Installing Mercedes W166 RAV Tool Box: Schritt 14, Bild 3 von 3
    • 4. Install box
    • Remove drawers and slide box on rail guides, align with bolt holes
    • Install 6 (M12) bolts and fully tighten to 66 Nm
  15. Installing Mercedes W166 RAV Tool Box: Schritt 15, Bild 1 von 3 Installing Mercedes W166 RAV Tool Box: Schritt 15, Bild 2 von 3 Installing Mercedes W166 RAV Tool Box: Schritt 15, Bild 3 von 3
    • Install drawers.
    • After drawer is installed move rail clip to locked position
  16. Installing Mercedes W166 RAV Tool Box: Schritt 16, Bild 1 von 1
    • Fasten seat belt with bolt to floor
Ziellinie
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Stefan
275 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 25
Letzte 30 Tage: 63
Insgesamt: 3,972
