Einleitung
Use this guide when you need to replace the motherboard.
Was du brauchst
With the H2.0 bit screwdriver, remove the two screws on the yellow waterproof cover
Apply a plastic opening tool to each of the corners and gently remove the casing
Remove the five silver screws from the inner casing using the PH00 screwdriver bit
Remove the six screws from the edge of the clear inner casing with the PH00 screwdriver bit
Carefully remove the screen from the silver casing using a prying tool or the black spudger
Gently push out the pins holding the orange tape down using the pointy end of the spudger
Remove three screws holding the silver screen casing to the motherboard using the PH00 bit screwdriver
Remove three screws holding the motherboard into the casing using the PH00 bit screwdriver bit
Remove the two screws holding the lens assembly to the motherboard using the PH00 bit screwdriver
Remove the three screws holding the button sensors to the battery casing using the PH00 screwdriver bit
Lift screen to reveal wires underneath
Remove soldering connecting screen to the motherboard
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
