Zum Hauptinhalt wechseln
Kihno Kit Album Battery Replacement
Was du brauchst
  1. Kihno Kit Album Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Kihno Kit Album Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Insert a spudger into the gap and pull downwards, so the top lifts up.
  2. Kihno Kit Album Battery Replacement: Schritt 2, Bild 1 von 2 Kihno Kit Album Battery Replacement: Schritt 2, Bild 2 von 2
    • Pull out the wired component from the Kihno for better access.
    • Remove the old battery by pulling outward towards yourself, starting from the top.
  3. Kihno Kit Album Battery Replacement: Schritt 3, Bild 1 von 1
    • Grab your new battery and place it where the old one was.
    • Angle the battery to where it is underneath the golden flap.
    • Push the rest of the battery down.
  4. Kihno Kit Album Battery Replacement: Schritt 4, Bild 1 von 1
    • Place the wired components back into the Kihno.
    • Ensure the white button is sticking from the outside through its designated hole.
  5. Kihno Kit Album Battery Replacement: Schritt 5, Bild 1 von 1
    • Using your fingers, push the top back into the Kihno.
Ziellinie
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 61
Insgesamt: 338
