Zum Hauptinhalt wechseln
Kindle PW2 fix screen scratch (replace screen surface layer/ light guide Replacement)
Was du brauchst
  1. Kindle PW2 fix screen scratch (replace screen surface layer/ light guide Replacement), TLDR: Schritt 1, Bild 1 von 1
    • To save your time, yes the screen surface layer, or officially named light guide, can be easily peeled off.
    • Don't worry, it will not damage the touch screen and will not affect the touch sensitivity.
    • Then you can crop any common anti-glare PET screen protector into suitable size to replace the light guide
  2. Kindle PW2 fix screen scratch (replace screen surface layer/ light guide Replacement), Uncover the frame: Schritt 2, Bild 1 von 2 Kindle PW2 fix screen scratch (replace screen surface layer/ light guide Replacement), Uncover the frame: Schritt 2, Bild 2 von 2
    • Actual guide starts from here, first uncover the frame. You may refer to other Kindle disassembly guide if you want more detailed steps.
  3. Kindle PW2 fix screen scratch (replace screen surface layer/ light guide Replacement), Peel off the light guide: Schritt 3, Bild 1 von 3 Kindle PW2 fix screen scratch (replace screen surface layer/ light guide Replacement), Peel off the light guide: Schritt 3, Bild 2 von 3 Kindle PW2 fix screen scratch (replace screen surface layer/ light guide Replacement), Peel off the light guide: Schritt 3, Bild 3 von 3
    • Start to peel off from any of the 4 corners. Just be careful not to scratch the touch screen, which is the glossy surface under this plastic light guide.
  4. Kindle PW2 fix screen scratch (replace screen surface layer/ light guide Replacement), The nanomiprinted anti-glare light: Schritt 4, Bild 1 von 3 Kindle PW2 fix screen scratch (replace screen surface layer/ light guide Replacement), The nanomiprinted anti-glare light: Schritt 4, Bild 2 von 3 Kindle PW2 fix screen scratch (replace screen surface layer/ light guide Replacement), The nanomiprinted anti-glare light: Schritt 4, Bild 3 von 3
    • This is the peeled off light guide. which is an anti-glare layer.
    • It has a thin sticky layer at the back to stick to the touch screen
  5. Kindle PW2 fix screen scratch (replace screen surface layer/ light guide Replacement), replace with an anti-glare screen protector: Schritt 5, Bild 1 von 2 Kindle PW2 fix screen scratch (replace screen surface layer/ light guide Replacement), replace with an anti-glare screen protector: Schritt 5, Bild 2 von 2
    • After peeling off the original light guide, replace with any common anti-glare PET screen protector
    • You may get a matt screen guard designed for kindle. But this one I got lower the resolution of the screen, i.e. the text became less clear.
    • I then tried another anti-glare iPad PET screen protector. Cut it into Kindle's size. This one does not lower the resolution, but the anti-glare effect is not as good as the original light guide.
  6. Kindle PW2 fix screen scratch (replace screen surface layer/ light guide Replacement), Compare to original light guide: Schritt 6, Bild 1 von 1
    • Refer to the image, the left is a PW with original light guide and the right is the one with iPad protector
    • The anti-glare-ness is not as good as before but at least the annoying scratches are gone. If you found any good anti-glare screen protector that is as good as the original nanoiprinted light guide. Please share with everyone.
Abschluss
To fix a PW with scratched display in a low cost. Instead of replacing the whole integrated screen part, we can replace the light guide with an anti-glare PET screen protector.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
potechto
163 Reputation
1 Anleitung geschrieben
10 Kommentare
Does the light work with the non original light guide layer?
Cyberman - Antwort
Yes the backlight will still work, 100%, no worries.
potechto -
Also thank you very much for the guide
Cyberman - Antwort
Thank you, fingers crossed, will try. I’ve managed to get these deep scratches on 2 kindles.
Cyberman - Antwort
Good luck! Feel free to share with us your fixing experience
potechto -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 37
Letzte 30 Tage: 214
Insgesamt: 4,021
