Zum Hauptinhalt wechseln
Logitech G910 Lights Replacement
Was du brauchst
  1. Logitech G910 Lights Replacement, Lights: Schritt 1, Bild 1 von 1
    • Unplug the keyboard from the computer.
  2. Logitech G910 Lights Replacement: Schritt 2, Bild 1 von 1
    • Flip the keyboard and unscrew the 15 back screws. The screws in the palm rest must be unscrewed and the palm rest removed to access the 6 screws at the bottom of the keyboard. (There are 2 lengths of screws the shorter ones are for the palm rest) There are also 2 screws under the nonslip pads of the palm rest.
  3. Logitech G910 Lights Replacement: Schritt 3, Bild 1 von 1
    • Release the front part using a spudger or flat screwdriver to gently pry. Lift off carefully.
  4. Logitech G910 Lights Replacement, Lift the film: Schritt 4, Bild 1 von 2 Logitech G910 Lights Replacement, Lift the film: Schritt 4, Bild 2 von 2
    • Gently lift up the plastic film in the top right corner.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
3 Kommentare
So what do I do after I take apart my keyboard?
CuddlyZebesian - Antwort
this guide is currently missing some steps. If you have figured it out, pls edit this guide.
tayola -
Desolder and replace LEDs the size of a grain of sand xD
This is definitely not a job I'd mark as "easy".
squallloire -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 9
Letzte 7 Tage: 24
Letzte 30 Tage: 104
Insgesamt: 6,100
