Zum Hauptinhalt wechseln
Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement
Was du brauchst
  1. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement, Joystick: Schritt 1, Bild 1 von 1
    • Unplug your controller from your console or pc.
  2. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: Schritt 2, Bild 1 von 3 Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: Schritt 2, Bild 2 von 3 Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: Schritt 2, Bild 3 von 3
    • Remove the four 3mm screws with a Philips #0 screwdriver.
  3. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: Schritt 3, Bild 1 von 3 Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: Schritt 3, Bild 2 von 3 Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: Schritt 3, Bild 3 von 3
    • Remove the six 0.9mm screws with a Phillips #00 screwdriver.
  4. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: Schritt 4, Bild 1 von 2 Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: Schritt 4, Bild 2 von 2
    • Remove the metal plate cover.
    • Find the lever inside of the controller.
  5. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: Schritt 5, Bild 1 von 3 Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: Schritt 5, Bild 2 von 3 Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: Schritt 5, Bild 3 von 3
    • Insert your Flathead screwdriver into the middle of the lever to hold it in place.
    • Twist the ball to remove it from the lever.
    • Remove the ball top from the lever.
  6. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: Schritt 6, Bild 1 von 2 Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: Schritt 6, Bild 2 von 2
    • Remove the four 1.1mm screws holding the lever in place with your Phillips #0 screwdriver.
  7. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: Schritt 7, Bild 1 von 1
    • Remove the lever from the casing of the controller.
  8. Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: Schritt 8, Bild 1 von 2 Mad Catz Street Fighter X Tekken Pro Fightstick Lever Replacement: Schritt 8, Bild 2 von 2
    • Pull the cable connected to the lever out of the socket.
    • Remove the lever from the case.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Jordan
184 Reputation
1 Anleitung geschrieben
York University, Team S15-G1, Allen Summer 2021 Mitglied von York University, Team S15-G1, Allen Summer 2021
YORK-ALLEN-SU21S15G1
1 Mitglied
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 16
Letzte 7 Tage: 128
Letzte 30 Tage: 218
Insgesamt: 1,792
