Einleitung
This guide demonstrates how to easily replace the battery in a Medtronic 670G Insulin Pump. Replacing the battery of this device is important so that that the device can regulate your insulin and blood sugar as needed. It is crucial for the user to keep track of their health needs. I hope that with this guide will help you on the maintenance of your device.
Was du brauchst
Place the small protrusion on the bottom of the clip into the slot on top of the battery housing, and turn it counter clockwise.
Remove the battery cap.
Dispose of the old battery according to your state guidelines.
Insert the new battery, making sure the negative end (the flat part of the battery) is facing down.
Turn on the pump and wait until the HOME screen load to make sure the battery is working.
Your Medtronic 670G insulin pump is good-to-go!
2 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Need one badly
Hello,
It looks like the Medtronic 670G uses standard AA batteries. You should be able to find AA batteries at most grocery and hardware stores, or online here. We hope that helps!
