Zum Hauptinhalt wechseln
Mini Fridge Hinges Replacement
Was du brauchst
  1. Mini Fridge Hinges Replacement, Hinges: Schritt 1, Bild 1 von 1
    • Remove the plug from the outlet. Be sure to grab from the head of the cord.
  2. Mini Fridge Hinges Replacement: Schritt 2, Bild 1 von 1
    • Remove all food items and shelves from the fridge.
    • Place removed contents to the side and if needed place food items in another fridge temporarily.
  3. Mini Fridge Hinges Replacement: Schritt 3, Bild 1 von 2 Mini Fridge Hinges Replacement: Schritt 3, Bild 2 von 2
    • Remove the cover to the top hinge to access the hinge and screws. If you are unable to remove the cover with your hands, use a flathead screwdriver to pry it off.
    • Remove the three 20 mm Phillips #1 screws from beneath the cover.
  4. Mini Fridge Hinges Replacement: Schritt 4, Bild 1 von 3 Mini Fridge Hinges Replacement: Schritt 4, Bild 2 von 3 Mini Fridge Hinges Replacement: Schritt 4, Bild 3 von 3
    • After removing the top hinge, lift the door off of the bottom hinge.
    • Place the door and removed top hinge securely to the side.
  5. Mini Fridge Hinges Replacement: Schritt 5, Bild 1 von 2 Mini Fridge Hinges Replacement: Schritt 5, Bild 2 von 2
    • Rotate the fridge onto its side.
    • Do not turn the fridge upside down to protect the internal components of the fridge.
    • Remove the two 19 mm Phillips #1 screws and the bottom hinge.
  6. Mini Fridge Hinges Replacement: Schritt 6, Bild 1 von 1
    • Install the bottom replacement hinge and the two 19 mm Phillips #1 screws.
    • Turn the fridge right side up after the bottom hinge is replaced.
  7. Mini Fridge Hinges Replacement: Schritt 7, Bild 1 von 1
    • Place the door on the bottom hinge, aligning the hole with the hinge.
    • Install the new top hinge and the three 20 mm Philips #1 screws. Ensure the orientation of the hinge lines up with the door.
    • Tighten as needed until the fridge door opens and closes normally and is not uneven.
    • Replace the top cover and the shelving inside the fridge.
Abschluss
This is a relatively easy fix and is easily repeatable. The replacement parts are inexpensive. We hope this guide extends the life of a mini fridge and expands your understanding of the topic.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
My fridge is not working Death ho gaya h bikul kuch bbi n chal rha h
Prince Singh - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 19
Letzte 30 Tage: 113
Insgesamt: 3,171
