Einleitung
This guide disassembles the capture button, so the device can be checked for a broken spring or for debris blocking its movement.
Was du brauchst
Then, carefully pry apart the front and back outer casing away from the internal components.
The button will spring free. The capture device consists of the plastic button and a small metal spring.
The button can be reassembled by using the tweezers to place the spring rectangle-side down on the button and snapping the button back into place.
Reassemble the casing by reversing steps 1 and 2.
