Zum Hauptinhalt wechseln
Model O- Mouse Cable Replacement
Was du brauchst
  1. Model O- Mouse Cable Replacement, Mouse Cable: Schritt 1, Bild 1 von 3 Model O- Mouse Cable Replacement, Mouse Cable: Schritt 1, Bild 2 von 3 Model O- Mouse Cable Replacement, Mouse Cable: Schritt 1, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Turn the mouse over so that the feet are facing you.
    • Remove the bottom two mouse feet using tweezers.
    • If you plan on reusing the mouse feet place them with the adhesive side up.
  2. Model O- Mouse Cable Replacement: Schritt 2, Bild 1 von 2 Model O- Mouse Cable Replacement: Schritt 2, Bild 2 von 2
    • Using a Phillips #0 screwdriver, remove the two screws that are under the mouse feet.
  3. Model O- Mouse Cable Replacement: Schritt 3, Bild 1 von 3 Model O- Mouse Cable Replacement: Schritt 3, Bild 2 von 3 Model O- Mouse Cable Replacement: Schritt 3, Bild 3 von 3
    • Slide the base away from the top housing to avoid the front clips.
    • Lift the top and place it down diagonal over the base, exposing the 5-pin connector.
    • Avoid putting strain on the thin LED ribbon cables.
  4. Model O- Mouse Cable Replacement: Schritt 4, Bild 1 von 2 Model O- Mouse Cable Replacement: Schritt 4, Bild 2 von 2
    • Use two fingers to grasp the top of the 5-pin connector under the edges and slowly lift the connector. If it is difficult, wiggle the plug slightly.
    • Do not pull on the wires.
    • Remove the cable from around the circuit board and from the hole on the front of the mouse.
  5. Model O- Mouse Cable Replacement: Schritt 5, Bild 1 von 2 Model O- Mouse Cable Replacement: Schritt 5, Bild 2 von 2
    • Insert the new cable's 5-pin connector plug (red) into the 5-pin connector socket (orange).
    • Do not push on the wires.
  6. Model O- Mouse Cable Replacement: Schritt 6, Bild 1 von 2 Model O- Mouse Cable Replacement: Schritt 6, Bild 2 von 2
    • Route the new cable through the slit in the circuit board.
    • Route the new cable behind the pillars.
    • Route the cable through the hole at the front of the mouse. Some cables have a fitted square plastic piece that positions the cable, some have thermoplastic which requires the user to position it themselves.
    • The cable may not stay in place until the top housing is securely fastened back on.
  7. Model O- Mouse Cable Replacement: Schritt 7, Bild 1 von 2 Model O- Mouse Cable Replacement: Schritt 7, Bild 2 von 2
    • Join the top and bottom housing together with the top around 1cm ahead of the bottom, then pull the top housing back as illustrated.
    • Once the two sides of the shell are together apply pressure until at least one screw is securely fastening them together.
  8. Model O- Mouse Cable Replacement: Schritt 8, Bild 1 von 1
    • Screw the two screws back in with a Phillips #0 screwdriver.
    • Do not apply too much force or you risk stripping the screw holes.
  9. Model O- Mouse Cable Replacement: Schritt 9, Bild 1 von 2 Model O- Mouse Cable Replacement: Schritt 9, Bild 2 von 2
    • Reapply the mouse feet with the adhesive side sticking to the mouse.
    • There are plastic ridges to help guide the user where to place the mouse feet.
    • Certain mouse cables come with new mouse feet which can be applied here instead of reapplying the old feet.
Ziellinie
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Theo SW
241 Reputation
1 Anleitung geschrieben
York University, Team S2-G24, O'Regan Winter 2021 Mitglied von York University, Team S2-G24, O'Regan Winter 2021
YORK-O'REGAN-W21S2G24
1 Mitglied
3 Anleitungen geschrieben
2 Kommentare
Where can I get the replacement cable for it?
Ekke Sten - Antwort
does glorius them selfs sell replacment parts ?
aniss-97 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 40
Letzte 30 Tage: 195
Insgesamt: 11,110
