Zum Hauptinhalt wechseln
Nikon N80 Viewfinder Replacement
Was du brauchst
  1. Nikon N80 Viewfinder Replacement, Viewfinder: Schritt 1, Bild 1 von 1
    • Make sure the On/Off switch is in the Off position.
  2. Nikon N80 Viewfinder Replacement: Schritt 2, Bild 1 von 3 Nikon N80 Viewfinder Replacement: Schritt 2, Bild 2 von 3 Nikon N80 Viewfinder Replacement: Schritt 2, Bild 3 von 3
    • Remove the four 4.8mm screws on the top section of the camera using a PH00 Phillips screwdriver.
    • Two are located by the viewfinder and and the other two are on each side of the camera.
  3. Nikon N80 Viewfinder Replacement: Schritt 3, Bild 1 von 2 Nikon N80 Viewfinder Replacement: Schritt 3, Bild 2 von 2
    • Rotate the camera so the bottom plate is accessible.
    • Remove the seven 4.8mm screws on the bottom plate of the camera using a PH00 Phillips screwdriver.
    • Separate the bottom plate.
  4. Nikon N80 Viewfinder Replacement: Schritt 4, Bild 1 von 1
    • Remove the five silver 4.8mm screws on the lens mount using a PH00 Phillips screwdriver.
    • Extract the lens mount.
  5. Nikon N80 Viewfinder Replacement: Schritt 5, Bild 1 von 3 Nikon N80 Viewfinder Replacement: Schritt 5, Bild 2 von 3 Nikon N80 Viewfinder Replacement: Schritt 5, Bild 3 von 3
    • Remove the seven 4.8mm screws on front camera plate using a PH00 Phillips screwdriver.
    • One is located on the battery chamber side of the camera, two are next to the film door release lever, two are located below the "Nikon" logo, and the last two are located above the "Nikon" logo in the Speedlight compartment.
  6. Nikon N80 Viewfinder Replacement: Schritt 6, Bild 1 von 1
    • Separate the three front camera plates from the camera.
  7. Nikon N80 Viewfinder Replacement: Schritt 7, Bild 1 von 1
    • Gently disconnect the top section of the camera from the body.
    • Don't pull the top section off too hard or the wire and ribbon within the camera may disconnect.
  8. Nikon N80 Viewfinder Replacement: Schritt 8, Bild 1 von 1
    • Remove the two 4.8mm screws next to the viewfinder with a PH00 Phillips screwdriver.
  9. Nikon N80 Viewfinder Replacement: Schritt 9, Bild 1 von 2 Nikon N80 Viewfinder Replacement: Schritt 9, Bild 2 von 2
    • Pull out the viewfinder gently.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Maegan Viloria
717 Reputation
5 Anleitungen geschrieben
CSU Fullerton, Team 1-7, Bruce Fall 2015 Mitglied von CSU Fullerton, Team 1-7, Bruce Fall 2015
CSUF-BRUCE-F15S1G7
3 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
This is a great guide, thank you!
Test Test - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 11
Letzte 30 Tage: 44
Insgesamt: 2,587
