Zum Hauptinhalt wechseln
Oliver Bagel and Bun Slicer 702-N Blade Replacement
Was du brauchst
  1. Oliver Bagel and Bun Slicer 702-N Blade Replacement, Blade: Schritt 1, Bild 1 von 1
    • Remove the black knob underneath the bagel slicer base by twisting it counterclockwise.
  2. Oliver Bagel and Bun Slicer 702-N Blade Replacement: Schritt 2, Bild 1 von 1
    • On the left end of the slicer, repeat the previous step to remove the bottom knob.
  3. Oliver Bagel and Bun Slicer 702-N Blade Replacement: Schritt 3, Bild 1 von 2 Oliver Bagel and Bun Slicer 702-N Blade Replacement: Schritt 3, Bild 2 von 2
    • Remove the knob located in the middle by twisting it counterclockwise.
    • After removing the knob, smoothly pull out the lock.
  4. Oliver Bagel and Bun Slicer 702-N Blade Replacement: Schritt 4, Bild 1 von 2 Oliver Bagel and Bun Slicer 702-N Blade Replacement: Schritt 4, Bild 2 von 2
    • Locate the knob on the left and repeat Step 3 to remove the knob and lock.
  5. Oliver Bagel and Bun Slicer 702-N Blade Replacement: Schritt 5, Bild 1 von 2 Oliver Bagel and Bun Slicer 702-N Blade Replacement: Schritt 5, Bild 2 von 2
    • While holding the ends of the bagel chute, lift the entire chute up and set it aside.
    • When you remove the chute, the sharp blade will be exposed. Take further caution as you proceed through the guide.
  6. Oliver Bagel and Bun Slicer 702-N Blade Replacement: Schritt 6, Bild 1 von 3 Oliver Bagel and Bun Slicer 702-N Blade Replacement: Schritt 6, Bild 2 von 3 Oliver Bagel and Bun Slicer 702-N Blade Replacement: Schritt 6, Bild 3 von 3
    • Remove all three nuts on the blade cover.
    • It’s important to separate and organize the different small parts in each step to ensure a smooth reassembling process.
  7. Oliver Bagel and Bun Slicer 702-N Blade Replacement: Schritt 7, Bild 1 von 2 Oliver Bagel and Bun Slicer 702-N Blade Replacement: Schritt 7, Bild 2 von 2
    • Carefully lift up the blade cover and set aside.
  8. Oliver Bagel and Bun Slicer 702-N Blade Replacement: Schritt 8, Bild 1 von 2 Oliver Bagel and Bun Slicer 702-N Blade Replacement: Schritt 8, Bild 2 von 2
    • Remove the black knobs on both sides of the blade and set aside.
    • Make sure that you keep these knobs separate from the knobs in Steps 1-6 as they look identical but are not interchangeable between each other.
  9. Oliver Bagel and Bun Slicer 702-N Blade Replacement: Schritt 9, Bild 1 von 1
    • Carefully lift up the part and set aside.
    • Hold the part by its ends so that your hands are as far from the blade as possible.
  10. Oliver Bagel and Bun Slicer 702-N Blade Replacement: Schritt 10, Bild 1 von 2 Oliver Bagel and Bun Slicer 702-N Blade Replacement: Schritt 10, Bild 2 von 2
    • Put on cut gloves before proceeding.
    • Using a 7/16 wrench, remove the three bolts.
    • You may spin the blade clockwise to make the removal process easier.
  11. Oliver Bagel and Bun Slicer 702-N Blade Replacement: Schritt 11, Bild 1 von 1
    • Carefully the lift the blade up and set aside in a safe spot.
    • Now is a great time to clean and wipe down all individual parts if needed.
  12. Oliver Bagel and Bun Slicer 702-N Blade Replacement: Schritt 12, Bild 1 von 2 Oliver Bagel and Bun Slicer 702-N Blade Replacement: Schritt 12, Bild 2 von 2
    • With a new blade, place the blade down and align the holes with the holes of the bagel slicer base.
  13. Oliver Bagel and Bun Slicer 702-N Blade Replacement: Schritt 13, Bild 1 von 1
    • Hold the blade with your non-dominant hand to keep it steady.
    • Screw back in all three bolts of the blade with your by twisting it clockwise.
  14. Oliver Bagel and Bun Slicer 702-N Blade Replacement: Schritt 14, Bild 1 von 1
    • Once the bolts are somewhat secured, use the 7/16 wrench again to tighten them until firm.
  15. Oliver Bagel and Bun Slicer 702-N Blade Replacement: Schritt 15, Bild 1 von 2 Oliver Bagel and Bun Slicer 702-N Blade Replacement: Schritt 15, Bild 2 von 2
    • Insert the part with the outward sticking bolt and place the part down.
    • Make sure to align the outward sticking bolt's hole with the screw.
  16. Oliver Bagel and Bun Slicer 702-N Blade Replacement: Schritt 16, Bild 1 von 2 Oliver Bagel and Bun Slicer 702-N Blade Replacement: Schritt 16, Bild 2 von 2
    • Twist the black knobs clockwise on both sides of the part until firmly tight.
    • Make sure you are using the same black knobs you removed in Step 10.
  17. Oliver Bagel and Bun Slicer 702-N Blade Replacement: Schritt 17, Bild 1 von 2 Oliver Bagel and Bun Slicer 702-N Blade Replacement: Schritt 17, Bild 2 von 2
    • Align the holes of the bagel cover with the bolts and place the cover down.
  18. Oliver Bagel and Bun Slicer 702-N Blade Replacement: Schritt 18, Bild 1 von 3 Oliver Bagel and Bun Slicer 702-N Blade Replacement: Schritt 18, Bild 2 von 3 Oliver Bagel and Bun Slicer 702-N Blade Replacement: Schritt 18, Bild 3 von 3
    • Twist all three nuts on the bagel cover clockwise until tight.
  19. Oliver Bagel and Bun Slicer 702-N Blade Replacement: Schritt 19, Bild 1 von 2 Oliver Bagel and Bun Slicer 702-N Blade Replacement: Schritt 19, Bild 2 von 2
    • On the bagel chute you removed in Step 5, align the lock's hole with the bolt.
    • Place a black knob on top and twist clockwise until tight.
  20. Oliver Bagel and Bun Slicer 702-N Blade Replacement: Schritt 20, Bild 1 von 3 Oliver Bagel and Bun Slicer 702-N Blade Replacement: Schritt 20, Bild 2 von 3 Oliver Bagel and Bun Slicer 702-N Blade Replacement: Schritt 20, Bild 3 von 3
    • Repeat Step 19 for the other knob.
    • After completing Steps 19 and 20, your bagel chute should look like the third image.
  21. Oliver Bagel and Bun Slicer 702-N Blade Replacement: Schritt 21, Bild 1 von 2 Oliver Bagel and Bun Slicer 702-N Blade Replacement: Schritt 21, Bild 2 von 2
    • Place the bagel chute on top of the metallic slicer base.
    • The bottom part of the lock should go underneath the base.
    • Line up the holes of the locks with the bolts and twist a black knob into the hole of the base.
    • Due to the obscure position of the bolt, you can insert the black knob into the lock first and move it back and forth until you feel a hole.
  22. Oliver Bagel and Bun Slicer 702-N Blade Replacement: Schritt 22, Bild 1 von 1
    • Repeat Step 21 for the lock on the other side.
  23. Oliver Bagel and Bun Slicer 702-N Blade Replacement: Schritt 23, Bild 1 von 1
    • Plug in the power cord to an outlet and turn it on. If it doesn't make a loud screeching sound, you've successfully reassembled the bagel slicer!
Abschluss
Andre Lam
337 Reputation
1 Anleitung geschrieben
UC Davis, Team 1-3, Andersen Winter 2023 Mitglied von UC Davis, Team 1-3, Andersen Winter 2023
UCD-ANDERSEN-W23S1G3
2 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 26
Insgesamt: 382
