Zum Hauptinhalt wechseln
Olympus 850SW Memory Card Replacement
  1. Olympus 850SW Memory Card Replacement, Memory Card: Schritt 1, Bild 1 von 1
    • Locate the memory card latch/ battery latch on the bottom panel of the camera and open it.
    • Make sure to remove the battery before trying to remove the memory card.
  2. Olympus 850SW Memory Card Replacement: Schritt 2, Bild 1 von 1
    • Hold the memory card so that the pointed wedge is facing up and the sticker is facing the front of the camera.
  3. Olympus 850SW Memory Card Replacement: Schritt 3, Bild 1 von 1
    • Hold the card so that the thicker end of it is to the right, and the flat end is facing the bottom of the camera.
    • Insert the card into the compartment fully until it clicks into place.
  4. Olympus 850SW Memory Card Replacement: Schritt 4, Bild 1 von 1
    • Close the memory card latch/ battery latch.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
How much gigabytes can I use on an Olympus 850 SW?
Yuan - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 13
Letzte 30 Tage: 50
Insgesamt: 1,736
