Zum Hauptinhalt wechseln
Olympus Stylus 1010 LCD Display Replacement
Was du brauchst
  1. Olympus Stylus 1010 LCD Display Replacement, Disassembling Olympus Stylus 1010 Case: Schritt 1, Bild 1 von 2 Olympus Stylus 1010 LCD Display Replacement, Disassembling Olympus Stylus 1010 Case: Schritt 1, Bild 2 von 2
    • Remove the five Phillips #00 bottom and right side panel screws.
  2. Olympus Stylus 1010 LCD Display Replacement: Schritt 2, Bild 1 von 1
    • Remove the right side panel by pulling off the large silver piece.
  3. Olympus Stylus 1010 LCD Display Replacement: Schritt 3, Bild 1 von 2 Olympus Stylus 1010 LCD Display Replacement: Schritt 3, Bild 2 von 2
    • Remove the remaining three Phillips #00 side and front panel screws.
  4. Olympus Stylus 1010 LCD Display Replacement: Schritt 4, Bild 1 von 1
    • Using your thumb and forefinger, pull off the silver name plate and silver "T-shape" piece.
  5. Olympus Stylus 1010 LCD Display Replacement: Schritt 5, Bild 1 von 1
    • Remove the black front panel by sliding it towards the lens and then pulling it up off of the camera.
  6. Olympus Stylus 1010 LCD Display Replacement: Schritt 6, Bild 1 von 3 Olympus Stylus 1010 LCD Display Replacement: Schritt 6, Bild 2 von 3 Olympus Stylus 1010 LCD Display Replacement: Schritt 6, Bild 3 von 3
    • Remove the three Phillips #00 screws from the front of the camera.
    • Using a spudger, lift the two tabs to separate the case—one tab on top and one tab on the right side.
  7. Olympus Stylus 1010 LCD Display Replacement: Schritt 7, Bild 1 von 3 Olympus Stylus 1010 LCD Display Replacement: Schritt 7, Bild 2 von 3 Olympus Stylus 1010 LCD Display Replacement: Schritt 7, Bild 3 von 3
    • Using a plastic spudger, lift up the black clips.
    • Still using the plastic spudger, detach the gold connector strip and white connector strip.
    • Using both hands, pull the camera apart into two pieces.
  8. Olympus Stylus 1010 LCD Display Replacement, LCD Display: Schritt 8, Bild 1 von 1
    • Peel up the blue and black tape. This can be done with a spudger.
  9. Olympus Stylus 1010 LCD Display Replacement: Schritt 9, Bild 1 von 2 Olympus Stylus 1010 LCD Display Replacement: Schritt 9, Bild 2 von 2
    • Unscrew the screws. (6 screws)( photo shows 7 screws -editorial comment)
  10. Olympus Stylus 1010 LCD Display Replacement: Schritt 10, Bild 1 von 2 Olympus Stylus 1010 LCD Display Replacement: Schritt 10, Bild 2 von 2
    • Push out the LCD screen by pushing on the screen side.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Curtis Reedy
267 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 13-4, Forte Winter 2011 Mitglied von Cal Poly, Team 13-4, Forte Winter 2011
CPSU-FORTE-W11S13G4
6 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 4,572
