Zum Hauptinhalt wechseln
Panasonic Camera DMC-FX07 Battery Replacement
  1. Panasonic Camera DMC-FX07 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Panasonic Camera DMC-FX07 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • The first step is to turn off the camera
    • Next, locate the battery door on the bottom of the camera
    • To open, slide the latch left, or towards the tripod mount
    • The door should spring open
  2. Panasonic Camera DMC-FX07 Battery Replacement: Schritt 2, Bild 1 von 3 Panasonic Camera DMC-FX07 Battery Replacement: Schritt 2, Bild 2 von 3 Panasonic Camera DMC-FX07 Battery Replacement: Schritt 2, Bild 3 von 3
    • Now that the door is open, release the spring clip on the right
    • The battery should pop out just enough so you can pull it out
    • Pull the battery out.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 26
Insgesamt: 980
