Zum Hauptinhalt wechseln
Panasonic DECT 6.0 Button Replacement
Was du brauchst
  1. Panasonic DECT  6.0 Button Replacement, Jammed/Broken Buttons: Schritt 1, Bild 1 von 3 Panasonic DECT  6.0 Button Replacement, Jammed/Broken Buttons: Schritt 1, Bild 2 von 3 Panasonic DECT  6.0 Button Replacement, Jammed/Broken Buttons: Schritt 1, Bild 3 von 3
    • Remove the battery cover by pushing the tab upwards and sliding it off.
    • Pull out the battery/energy source from its slot.
    • Keep all pieces in a safe and orderly manner for ease of reassembly.
  2. Panasonic DECT  6.0 Button Replacement: Schritt 2, Bild 1 von 3 Panasonic DECT  6.0 Button Replacement: Schritt 2, Bild 2 von 3 Panasonic DECT  6.0 Button Replacement: Schritt 2, Bild 3 von 3
    • Unscrew the screws you see on the inside of the casing using an appropriate screwdriver from the JIS Driver Set.
    • Carefully pry each side open with the iFixit Opening tool.
    • Detach the back of the phone case.
  3. Panasonic DECT  6.0 Button Replacement: Schritt 3, Bild 1 von 3 Panasonic DECT  6.0 Button Replacement: Schritt 3, Bild 2 von 3 Panasonic DECT  6.0 Button Replacement: Schritt 3, Bild 3 von 3
    • Unscrew the screws to remove the motherboard using an appropriate screwdriver from the JIS Driver Set.
    • Potential for device damage
  4. Panasonic DECT  6.0 Button Replacement: Schritt 4, Bild 1 von 3 Panasonic DECT  6.0 Button Replacement: Schritt 4, Bild 2 von 3 Panasonic DECT  6.0 Button Replacement: Schritt 4, Bild 3 von 3
    • Carefully pull off the circuitry and cords from the front half of the phone and set them aside.
    • Bring the buttons to the front.
  5. Panasonic DECT  6.0 Button Replacement: Schritt 5, Bild 1 von 2 Panasonic DECT  6.0 Button Replacement: Schritt 5, Bild 2 von 2
    • Pull gently to separate the button pad from the phone cover.
    • Identify the broken/jammed button you were having issues with.
    • Replace or return the button to its function.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Jacob
131 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 19
Insgesamt: 521
