Zum Hauptinhalt wechseln
Panasonic Lumix DMC-FX01 Front Casing Replacement
Was du brauchst
  1. Panasonic Lumix DMC-FX01 Front Casing Replacement, Battery: Schritt 1, Bild 1 von 1
    • Locate the memory card and battery card latch on the bottom of the camera.
    • Slide the latch to the open position.
  2. Panasonic Lumix DMC-FX01 Front Casing Replacement: Schritt 2, Bild 1 von 1
    • Open the battery latch, and slide the battery release lever to the right.
  3. Panasonic Lumix DMC-FX01 Front Casing Replacement: Schritt 3, Bild 1 von 1
    • Remove the battery from the camera.
  4. Panasonic Lumix DMC-FX01 Front Casing Replacement, Rear Casing: Schritt 4, Bild 1 von 1
    • Remove the three 4.6 mm screws on the bottom of the camera using a Phillips #00 screwdriver.
  5. Panasonic Lumix DMC-FX01 Front Casing Replacement: Schritt 5, Bild 1 von 1
    • Remove the single 3.2 mm screw on the left side of the camera using a Phillips #00 screwdriver.
  6. Panasonic Lumix DMC-FX01 Front Casing Replacement: Schritt 6, Bild 1 von 2 Panasonic Lumix DMC-FX01 Front Casing Replacement: Schritt 6, Bild 2 von 2
    • Remove the left side casing.
  7. Panasonic Lumix DMC-FX01 Front Casing Replacement: Schritt 7, Bild 1 von 1
    • Remove the two 3.2 mm screws on the right side of the camera using a Phillips #00 screwdriver.
  8. Panasonic Lumix DMC-FX01 Front Casing Replacement: Schritt 8, Bild 1 von 1
    • Remove the bottom right panel.
  9. Panasonic Lumix DMC-FX01 Front Casing Replacement: Schritt 9, Bild 1 von 2 Panasonic Lumix DMC-FX01 Front Casing Replacement: Schritt 9, Bild 2 von 2
    • Gently remove the back casing.
    • Start at the bottom and carefully pry towards the top to get this piece free.
  10. Panasonic Lumix DMC-FX01 Front Casing Replacement, LCD Screen: Schritt 10, Bild 1 von 1
    • Gently lift up the LCD screen.
    • Using a plastic prying tool, flip up the latch that holds the thin ribbon in place.
    • It should fall out on its own or with a gentle tug.
  11. Panasonic Lumix DMC-FX01 Front Casing Replacement: Schritt 11, Bild 1 von 1
    • Gently tug the thicker ribbon to remove it from its housing.
  12. Panasonic Lumix DMC-FX01 Front Casing Replacement, Front Casing: Schritt 12, Bild 1 von 2 Panasonic Lumix DMC-FX01 Front Casing Replacement, Front Casing: Schritt 12, Bild 2 von 2
    • Remove the two black 5.4 mm screws that hold in the front faceplate using a Phillips #00 screwdriver.
    • There may be a third screw the the right of the lens assembly.
  13. Panasonic Lumix DMC-FX01 Front Casing Replacement: Schritt 13, Bild 1 von 3 Panasonic Lumix DMC-FX01 Front Casing Replacement: Schritt 13, Bild 2 von 3 Panasonic Lumix DMC-FX01 Front Casing Replacement: Schritt 13, Bild 3 von 3
    • Carefully remove the upper assembly, which houses the buttons and the flash battery.
  14. Panasonic Lumix DMC-FX01 Front Casing Replacement: Schritt 14, Bild 1 von 1
    • Carefully remove the front casing after verifying that the thin plastic around the lens is not still attached.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Andrew
396 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 9-22, Regan Fall 2010 Mitglied von Cal Poly, Team 9-22, Regan Fall 2010
CPSU-REGAN-F10S9G22
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 10
Insgesamt: 4,291
