Zum Hauptinhalt wechseln
Panasonic Lumix DMC-FZ35 LCD Replacement
Was du brauchst
  1. Panasonic Lumix DMC-FZ35 LCD Replacement, Clear compartment: Schritt 1, Bild 1 von 1
    • Remove the battery and memory card from the unit.
  2. Panasonic Lumix DMC-FZ35 LCD Replacement, Remove side screws: Schritt 2, Bild 1 von 2 Panasonic Lumix DMC-FZ35 LCD Replacement, Remove side screws: Schritt 2, Bild 2 von 2
    • Remove 1 screw (0.4mm) from left side of unit
    • Remove 1 screw (0.4mm) from right side of unit near Strap bar.
    • Remove 1 screw (0.6mm) from right side of unit next to usb door
  3. Panasonic Lumix DMC-FZ35 LCD Replacement, Remove Screws from Bottom: Schritt 3, Bild 1 von 1
    • Remove 3 Screws from bottom of unit
    • Remove 2 (0.6mm) screws next to door
    • Remove 1 (0.4mm) screw opposite of door
  4. Panasonic Lumix DMC-FZ35 LCD Replacement, Remove top screw: Schritt 4, Bild 1 von 1
    • Raise the Pop-Up flash by pushing the flash button.
    • Remove the screw (0.6mm) from underneath the flash assembly.
  5. Panasonic Lumix DMC-FZ35 LCD Replacement, Accessing the flex cables: Schritt 5, Bild 1 von 2 Panasonic Lumix DMC-FZ35 LCD Replacement, Accessing the flex cables: Schritt 5, Bild 2 von 2
    • Please be careful. Do not lift the cover fully because it is still attached to the Main Board via flex cables.
    • Lift the cover slightly as shown in picture # 1
    • Tilt the back cover as shown in picture #2. Be careful because the flex cables are still attached.
  6. Panasonic Lumix DMC-FZ35 LCD Replacement, Release the Flex cables: Schritt 6, Bild 1 von 3 Panasonic Lumix DMC-FZ35 LCD Replacement, Release the Flex cables: Schritt 6, Bild 2 von 3 Panasonic Lumix DMC-FZ35 LCD Replacement, Release the Flex cables: Schritt 6, Bild 3 von 3
    • Flip up LCD cable clamp with a spudger or other tool.
    • Flip up backlite cable clamp with a spudger or other tool
    • Removal of the mic wire is optional. My suggestion is to leave it attached. The mic can get damaged if you pull on the wire.
  7. Panasonic Lumix DMC-FZ35 LCD Replacement, Remove the mic: Schritt 7, Bild 1 von 3 Panasonic Lumix DMC-FZ35 LCD Replacement, Remove the mic: Schritt 7, Bild 2 von 3 Panasonic Lumix DMC-FZ35 LCD Replacement, Remove the mic: Schritt 7, Bild 3 von 3
    • Remove the 2 screws (0.4mm) that are holding the mic assembly
    • Next step (shown in picture #2) remove the metal mic hold part.
    • Next step (shown in picture #3) use a spudger to pry off the mic. Careful not to damage the wiring.
  8. Panasonic Lumix DMC-FZ35 LCD Replacement, Remove the LCD: Schritt 8, Bild 1 von 3 Panasonic Lumix DMC-FZ35 LCD Replacement, Remove the LCD: Schritt 8, Bild 2 von 3 Panasonic Lumix DMC-FZ35 LCD Replacement, Remove the LCD: Schritt 8, Bild 3 von 3
    • Release the hold clips that hold the LCD retainer in place.
    • Remove the LCD metal retainer plate as shown in picture #2
    • Remove the LCD as shown in picture # 3
  9. Panasonic Lumix DMC-FZ35 LCD Replacement, Swap out Old LCD: Schritt 9, Bild 1 von 1
    • Swap out your old LCD with the new one.
    • If your backlite is ok you can buy only the LCD Display. But it is easier to purchase the LCD with the backlite attached. Replacement LCD Display VYQ5034
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 20
Insgesamt: 1,482
