Zum Hauptinhalt wechseln
Panasonic Lumix DMC-GX85 Rear Cover Replacement
Was du brauchst
  1. Panasonic Lumix DMC-GX85 Rear Cover Replacement, Rear Cover: Schritt 1, Bild 1 von 3 Panasonic Lumix DMC-GX85 Rear Cover Replacement, Rear Cover: Schritt 1, Bild 2 von 3 Panasonic Lumix DMC-GX85 Rear Cover Replacement, Rear Cover: Schritt 1, Bild 3 von 3
    • Remove the plastic hot shoe cover by sliding it towards the rear of the camera.
  2. Panasonic Lumix DMC-GX85 Rear Cover Replacement: Schritt 2, Bild 1 von 3 Panasonic Lumix DMC-GX85 Rear Cover Replacement: Schritt 2, Bild 2 von 3 Panasonic Lumix DMC-GX85 Rear Cover Replacement: Schritt 2, Bild 3 von 3
    • Using a spudger, gently lift the forward end of the shoe spring to disengage its locking mechanism.
    • While holding the forward end of the shoe spring up, push from its lifted end to remove the shoe spring.
  3. Panasonic Lumix DMC-GX85 Rear Cover Replacement: Schritt 3, Bild 1 von 2 Panasonic Lumix DMC-GX85 Rear Cover Replacement: Schritt 3, Bild 2 von 2
    • Remove the two 6.0mm silver Phillips #0 screws closest to the display screen.
    • Do not remove the two forward-most silver screws.
  4. Panasonic Lumix DMC-GX85 Rear Cover Replacement: Schritt 4, Bild 1 von 2 Panasonic Lumix DMC-GX85 Rear Cover Replacement: Schritt 4, Bild 2 von 2
    • Turn the camera so the side with the jack cover is facing you.
    • Near the camera's top end, remove the 4.0mm black Phillips #0 screw on the bottom in this orientation.
    • Open the jack cover and remove the 4.0mm black Phillips #0 screw inside.
  5. Panasonic Lumix DMC-GX85 Rear Cover Replacement: Schritt 5, Bild 1 von 2 Panasonic Lumix DMC-GX85 Rear Cover Replacement: Schritt 5, Bild 2 von 2
    • Flip the camera upside down so the bottom of the camera is facing you.
    • Remove the two center 2.5mm black Phillips #0 screws.
    • Remove the outer 4.5mm black Phillips #0 screw.
  6. Panasonic Lumix DMC-GX85 Rear Cover Replacement: Schritt 6, Bild 1 von 3 Panasonic Lumix DMC-GX85 Rear Cover Replacement: Schritt 6, Bild 2 von 3 Panasonic Lumix DMC-GX85 Rear Cover Replacement: Schritt 6, Bild 3 von 3
    • Turn the camera so the display screen is facing you.
    • Rotate the top of the screen away from the camera body to access and remove the 4.5mm black Phillips #0 screw.
    • Remove the rear camera cover by gently pulling from the top side.
    • When removing the rear cover, pull apart slowly to prevent damaging the ribbon cable connecting the display screen and the Sub PCB.
  7. Panasonic Lumix DMC-GX85 Rear Cover Replacement: Schritt 7, Bild 1 von 3 Panasonic Lumix DMC-GX85 Rear Cover Replacement: Schritt 7, Bild 2 von 3 Panasonic Lumix DMC-GX85 Rear Cover Replacement: Schritt 7, Bild 3 von 3
    • Turn the camera so the lens is facing down with the rear cover pulled back.
    • Disconnect the ribbon cable from the camera by pulling up on the black locking tab with an iFixit opening tool.
    • Pull the ribbon cable from the connector. The rear cover is now completely detached from the camera.
    • Do not bend the ribbon cable excessively and take care not to damage the ribbon cable.
Abschluss
Kristen Gismondi
83.188 Reputation
204 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
137 Mitglieder
17.525 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 23
Insgesamt: 1,184
