Zum Hauptinhalt wechseln
Pine64 PinePhone Charging Port Replacement
Was du brauchst
  1. Pine64 PinePhone Charging Port Replacement, Back Cover: Schritt 1, Bild 1 von 2 Pine64 PinePhone Charging Port Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Place the device face down on a non-scratch surface.
  2. Pine64 PinePhone Charging Port Replacement: Schritt 2, Bild 1 von 1
    • Using a fingernail pry open the back cover off with the bottom left indent.
  3. Pine64 PinePhone Charging Port Replacement, Charging Port: Schritt 3, Bild 1 von 3 Pine64 PinePhone Charging Port Replacement, Charging Port: Schritt 3, Bild 2 von 3 Pine64 PinePhone Charging Port Replacement, Charging Port: Schritt 3, Bild 3 von 3
    • Using a Phillips #000 screwdriver, remove each of the screws around the perimeter of the PinePhone.
    • Remove the battery.
  4. Pine64 PinePhone Charging Port Replacement: Schritt 4, Bild 1 von 1
    • Remove the midframe from the phone.
  5. Pine64 PinePhone Charging Port Replacement: Schritt 5, Bild 1 von 1
    • Carefully lift up the vibrator, connected to the board by two wires.
  6. Pine64 PinePhone Charging Port Replacement: Schritt 6, Bild 1 von 1
    • Applying even pressure, lift up the board.
    • An adhesive is all that is keeping it to the frame of the phone, so there should be minimum resistance.
    • With a new adhesive strip, connect the replacement board to the frame. Make sure to secure the vibrator in the same place as the original.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 53
Insgesamt: 987
