Zum Hauptinhalt wechseln
Pine64 PinePhone Volume Buttons Replacement
Was du brauchst
  1. Pine64 PinePhone Volume Buttons Replacement, Back Cover: Schritt 1, Bild 1 von 2 Pine64 PinePhone Volume Buttons Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Place the device face down on a non-scratch surface.
  2. Pine64 PinePhone Volume Buttons Replacement: Schritt 2, Bild 1 von 1
    • Using a fingernail pry open the back cover off with the bottom left indent.
  3. Pine64 PinePhone Volume Buttons Replacement, Battery: Schritt 3, Bild 1 von 1
    • Using a fingernail, press into the bottom divot and remove the battery from the phone.
  4. Pine64 PinePhone Volume Buttons Replacement, Motherboard: Schritt 4, Bild 1 von 1
    • Use a spudger or plastic opening tool to pry off the plastic cover.
  5. Pine64 PinePhone Volume Buttons Replacement: Schritt 5, Bild 1 von 1
    • Use a spudger to lift the ZIF tabs and press-fit connectors free.
  6. Pine64 PinePhone Volume Buttons Replacement: Schritt 6, Bild 1 von 1
    • Use a spudger to lift the motherboard up and remove it from the device.
  7. Pine64 PinePhone Volume Buttons Replacement, Volume Buttons: Schritt 7, Bild 1 von 1
    • Use a spudger to gently pry the volume button off of the phone.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 22
Insgesamt: 241
