Zum Hauptinhalt wechseln
Pokémon™ GO Plus+ Vibration Motor Disable
Was du brauchst
  1. Pokémon™ GO Plus+ Vibration Motor Disable, Remove the two screws from the bottom: Schritt 1, Bild 1 von 1
    • Flanking both sides of the charging port are J00 Screws. Remove these.
    • These screws go into plastic, so when re-assembling the device, be very careful not to over tighten them.
    • These two screws are identical to each other, but differ from the screws within the device, keep them separate from any screws you remove from within the device.
  2. Pokémon™ GO Plus+ Vibration Motor Disable, Remove Faceplace: Schritt 2, Bild 1 von 2 Pokémon™ GO Plus+ Vibration Motor Disable, Remove Faceplace: Schritt 2, Bild 2 von 2
    • When looking at the front of the device, with the charging point at the bottom the device has a hinge clip and wires on the top right.
    • While opening, be extremely careful not to damage the fragile cables and connection between the main body and the faceplate.
    • With a fingernail or some kind of slim pry tool, gently lift from the bottom left corner.
    • There is adhesive that is holding the faceplate on, If you have difficulty pulling it off, use a plastic spudger by inserting it in on the bottom left then slowly hinge the device open while applying pressure to the adhesive pad to loosen it.
  3. Pokémon™ GO Plus+ Vibration Motor Disable, Cut the motor wire: Schritt 3, Bild 1 von 1
    • Cut the black wire connected to the motor. This vibration motor is soldered directly to the main board, and there is no way to disconnect it without severing the cable.
    • This is a one way change. after cutting this cable you cannot re-connect it to get vibration back without much more difficult soldering work.
    • As an alternative to fully disabling the motor by disconnecting it, you can take a metal file to the counterweight on the motor. Removing excess mass from this weight will drastically soften the vibration
    • Using a small bit of electrical tape or glue, cover the ends of the wire you snipped so they don't short out on anything else inside the device.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
David
576 Reputation
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 80
Letzte 30 Tage: 292
Insgesamt: 965
