Zum Hauptinhalt wechseln
Polar M400 Watch Battery Replacement
Was du brauchst
  1. Polar M400 Watch Battery Replacement, Wrist Strap: Schritt 1, Bild 1 von 1
    • Insert a standard paper clip into the holes on both sides of the watch that connect the watch's face with the wrist strap.
  2. Polar M400 Watch Battery Replacement: Schritt 2, Bild 1 von 2 Polar M400 Watch Battery Replacement: Schritt 2, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Apply an upward pressure to the holes until the locking pins release.
    • Use precision tweezers to remove the pins that connect the face with the strap.
  3. Polar M400 Watch Battery Replacement: Schritt 3, Bild 1 von 1
    • Once the pins are released, the old wrist strap should snap off.
    • Simply lock the new wrist strap into place.
  4. Polar M400 Watch Battery Replacement, Battery: Schritt 4, Bild 1 von 1
    • Use the T5 head on the iFixit screwdriver to unscrew the four screws on the back of the watch’s face.
  5. Polar M400 Watch Battery Replacement: Schritt 5, Bild 1 von 2 Polar M400 Watch Battery Replacement: Schritt 5, Bild 2 von 2
    • Gently remove the backing from the watch.
  6. Polar M400 Watch Battery Replacement: Schritt 6, Bild 1 von 2 Polar M400 Watch Battery Replacement: Schritt 6, Bild 2 von 2
    Kaufen
    • Use tweezers to gently pry the golden sensor away from the battery.
    • Remove battery using the plastic opening tools.
Abschluss
15 weitere Nutzer:innen haben diese Anleitung absolviert.
University of Maine, Team S1-G3, Diaz Fall 2017 Mitglied von University of Maine, Team S1-G3, Diaz Fall 2017
UMAINE-DIAZ-F17S1G3
4 Mitglieder
7 Anleitungen geschrieben
25 Kommentare
Hello, thanks for the details !
The most tricky part: find the right spare part. I can’t find a replacement battery that could fit the original dimensions with reasonnable capacity.
Do you have any lead?
Vincent - Antwort
In case if anyone is still looking for the spare part I have just replaced my M400 battery with this one: https://www.aliexpress.com/item/10050045...
Replacement instructions were detailed enough to get my watch to work again.
Roman -
Bonjour
Pourriez-vous m’indiquer ou je peux acheter une batterie compatible ou originale
Merci à vous
ducellier - Antwort
where can i buy a batery for my polar m400? Link please. Thanks
lsmi_21 - Antwort
Once the battery is changed, the M400 does not work. Do you have to press any combination of keys?
lojobis - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 52
Letzte 30 Tage: 243
Insgesamt: 29,671
