Zum Hauptinhalt wechseln
Power Mac G5 Top Left Cooling Fan Unit Replacement
  1. Power Mac G5 Top Left Cooling Fan Unit Replacement, Side Panel: Schritt 1, Bild 1 von 1
    • To avoid electrocution, shut down the computer. Do not open the computer or attempt to install any items inside it while the computer is on.
    • To avoid being burned, wait at least 10 minutes to allow the computer's internal components to cool.
  2. Power Mac G5 Top Left Cooling Fan Unit Replacement: Schritt 2, Bild 1 von 1
    • Remove all the cables, including the power cables before opening the unit.
  3. Power Mac G5 Top Left Cooling Fan Unit Replacement: Schritt 3, Bild 1 von 2 Power Mac G5 Top Left Cooling Fan Unit Replacement: Schritt 3, Bild 2 von 2
    • Lift the tab to unlock the side panel.
    • The panel should fall out. If the panel does not fall out by itself pull a little from the edges.
  4. Power Mac G5 Top Left Cooling Fan Unit Replacement: Schritt 4, Bild 1 von 3 Power Mac G5 Top Left Cooling Fan Unit Replacement: Schritt 4, Bild 2 von 3 Power Mac G5 Top Left Cooling Fan Unit Replacement: Schritt 4, Bild 3 von 3
    • Remove the air deflector (the clear plastic cover) by pulling on the handle.
  5. Power Mac G5 Top Left Cooling Fan Unit Replacement, Top Left Cooling Fan Unit: Schritt 5, Bild 1 von 1
    • Locate the top left cooling fan unit.
  6. Power Mac G5 Top Left Cooling Fan Unit Replacement: Schritt 6, Bild 1 von 1
    • Pull the fan straight out from its slot. You will need to remove two cables from the motherboard.
    • It may be easier to reach the cables if you remove the PCI guide (next to the fan unit) first.
  7. Power Mac G5 Top Left Cooling Fan Unit Replacement: Schritt 7, Bild 1 von 1
    • After pulling out the fan unit, the area should look like this.
Abschluss
20 weitere Nutzer:innen haben diese Anleitung absolviert.
Salvador Aguilar
2.481 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 5-8, Forte Winter 2010 Mitglied von Cal Poly, Team 5-8, Forte Winter 2010
CPSU-FORTE-W10S5G8
7 Mitglieder
20 Anleitungen geschrieben
Ein Kommentar
Actually you do need to remove the plastic air deflector, as the fan in question is behind it.
Tim downing - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 13
Insgesamt: 19,118
