Einleitung
Having troubles charging your Razer Phone and need to replace the charging port? Follow this easy guide on how to do so.
Was du brauchst
Remove the plastic speaker grills by using the metal spudger to pry underneath the strips.
Peel off the plastic speaker grill to reveal the screws.
Remove five (two bottom, three top) 2.5 mm screws with the Phillips #000 screwdriver.
Remove five (four bottom, one top) 5.5 mm screws with the Torx Head T5 screwdriver.
Remove the display assembly by using the Jimmy to separate the assembly from the phone's frame.
Lift the display assembly away from the other half of the phone.
Grab hold of the the screen ribbon with the tweezers and remove it from the rest of the phone to free the assembly display.
Remove the 2.5 mm screw holding down the bracket with a Phillips #000 screwdriver.
Grab the bracket with the tweezers and remove it.
Using a Phillips #000 screwdriver, take out the seven 1 mm screws on the bottom panel of the device.
Use the tweezers to grab hold of the connector for the blue wire (bottom of the device), and remove the connector.
Use the tweezers to grab hold of the connector for the white wire, and remove the connector.
14 weitere Nutzer:innen haben diese Anleitung absolviert.
10 Kommentare
Search it on Amazon.c
hi how much you guys charge for the charging port thanks
