Zum Hauptinhalt wechseln
Repair Loose Floorboard Carpet in Vehicle
Was du brauchst
  1. Repair Loose Floorboard Carpet in Vehicle, Floorboard Carpeting: Schritt 1, Bild 1 von 2 Repair Loose Floorboard Carpet in Vehicle, Floorboard Carpeting: Schritt 1, Bild 2 von 2
    • Pull back detached carpet from the floorboard to determine how much carpet is detached.
  2. Repair Loose Floorboard Carpet in Vehicle: Schritt 2, Bild 1 von 2 Repair Loose Floorboard Carpet in Vehicle: Schritt 2, Bild 2 von 2
    • Apply a generous layer of spray adhesive to floorboard.
    • Wear a mask to prevent inhalation of fumes.
    • Wear gloves to prevent the adhesive from sticking to your hands.
    • Perform repair in a well ventilated area.
  3. Repair Loose Floorboard Carpet in Vehicle: Schritt 3, Bild 1 von 1
    • Allow 15-30 seconds for adhesive to dry before attaching carpet to floorboard.
  4. Repair Loose Floorboard Carpet in Vehicle: Schritt 4, Bild 1 von 2 Repair Loose Floorboard Carpet in Vehicle: Schritt 4, Bild 2 von 2
    • Apply carpet to floorboard firmly using hands.
    • This step needs to be repeated until carpet is in place with no wrinkles or bulges.
  5. Repair Loose Floorboard Carpet in Vehicle: Schritt 5, Bild 1 von 2 Repair Loose Floorboard Carpet in Vehicle: Schritt 5, Bild 2 von 2
    • Use a plastic squeegee to tuck the corner of the carpet into the paneling of the floorboard.
  6. Repair Loose Floorboard Carpet in Vehicle: Schritt 6, Bild 1 von 1
    • Vacuum floorboard to remove any debris or dirt.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2019 Mitglied von USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2019
USFSM-STEWART-S19S1G1
18 Mitglieder
27 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 34
Letzte 30 Tage: 149
Insgesamt: 6,347
