Zum Hauptinhalt wechseln
Repairing iPhone 4 dust mesh
Was du brauchst
  1. Repairing iPhone 4 dust mesh, Repairing iPhone 4 dust mesh: Schritt 1, Bild 1 von 2 Repairing iPhone 4 dust mesh, Repairing iPhone 4 dust mesh: Schritt 1, Bild 2 von 2
    • Left image shows iPhone with missing front dust mesh
    • Right image shows dust meshes on bottom
  2. Repairing iPhone 4 dust mesh: Schritt 2, Bild 1 von 2 Repairing iPhone 4 dust mesh: Schritt 2, Bild 2 von 2
    • Cut out a piece of stainless steel mesh of the tea filter using a pocket knife
    • Trim the piece of mesh using a pair of scissors to a size of approx. 3x9 mm
  3. Repairing iPhone 4 dust mesh: Schritt 3, Bild 1 von 2 Repairing iPhone 4 dust mesh: Schritt 3, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Fold the piece of mesh longways using the plastic tip
    • Use a pair of tweezers to insert the folded piece of mesh into the hole above the speaker
    • Put piece of mesh into place using plastic tip
    • That's it - see the result on the images
Ziellinie
28 weitere Nutzer:innen haben diese Anleitung absolviert.
aiwo
2.286 Reputation
1 Anleitung geschrieben
Ein Kommentar
This may work fine for most dirt, but with the original design there is also a cloth mesh behind the metal mesh that helps to keep finer particles out of the speaker.
This is definitely a much much much easier way to get some sort of protection in there at least. :)
Rene Jeddore - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 50,290
