Zum Hauptinhalt wechseln
Replacing Oakley Flak 2 Lens and Rubber Kits
Was du brauchst
  1. Replacing Oakley Flak 2 Lens and Rubber Kits, Lens & Rubber Kits: Schritt 1, Bild 1 von 3 Replacing Oakley Flak 2 Lens and Rubber Kits, Lens & Rubber Kits: Schritt 1, Bild 2 von 3 Replacing Oakley Flak 2 Lens and Rubber Kits, Lens & Rubber Kits: Schritt 1, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Pinch the tweezers and place them against the rubber ear socket.
    • Push the tweezers through the hole.
    • Slowly pull out the rubber ear sock.
    • Repeat the previous steps for the other side.
  2. Replacing Oakley Flak 2 Lens and Rubber Kits: Schritt 2, Bild 1 von 2 Replacing Oakley Flak 2 Lens and Rubber Kits: Schritt 2, Bild 2 von 2
    • Pull up on the bottom of the rubber nose pad.
    • Push the rubber nose pad up to remove it.
    • Repeat the steps for the other side.
  3. Replacing Oakley Flak 2 Lens and Rubber Kits: Schritt 3, Bild 1 von 2 Replacing Oakley Flak 2 Lens and Rubber Kits: Schritt 3, Bild 2 von 2
    • From the bridge of the glasses, push the bottom outer corner of the lens up.
    • Use the groove to slide the dislodged side of the lens down and out.
  4. Replacing Oakley Flak 2 Lens and Rubber Kits: Schritt 4, Bild 1 von 3 Replacing Oakley Flak 2 Lens and Rubber Kits: Schritt 4, Bild 2 von 3 Replacing Oakley Flak 2 Lens and Rubber Kits: Schritt 4, Bild 3 von 3
    • Make sure to match the correct ear sock to the correct temple side.
    • Insert the glasses temple in the rubber sock
    • Push/ Pull the rubber sock forward.
    • Push in the rubber tab into the hole near the hinge.
  5. Replacing Oakley Flak 2 Lens and Rubber Kits: Schritt 5, Bild 1 von 3 Replacing Oakley Flak 2 Lens and Rubber Kits: Schritt 5, Bild 2 von 3 Replacing Oakley Flak 2 Lens and Rubber Kits: Schritt 5, Bild 3 von 3
    • Insert the rubber nose pad from the top.
    • Stretch the nose pad at the bottom and insert the bottom tab into nose pad.
  6. Replacing Oakley Flak 2 Lens and Rubber Kits: Schritt 6, Bild 1 von 3 Replacing Oakley Flak 2 Lens and Rubber Kits: Schritt 6, Bild 2 von 3 Replacing Oakley Flak 2 Lens and Rubber Kits: Schritt 6, Bild 3 von 3
    • Insert the lens from the outer top corner.
    • Push the bottom corner of the lens closest to the frame's bridge up. An auditable pop will indicate the lens is inserted.
    • Repeat these steps for the other side.
  7. Replacing Oakley Flak 2 Lens and Rubber Kits: Schritt 7, Bild 1 von 2 Replacing Oakley Flak 2 Lens and Rubber Kits: Schritt 7, Bild 2 von 2
    Microfiber Cleaning Cloths
    $3.99
    Kaufen
Abschluss
This guide can allow you to mix and match various rubber kits, and lens to create your own Oakley Flak 2 sunglasses.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Peter Tran
193 Reputation
1 Anleitung geschrieben
York University, Team S2-G27, Melo-Thaiss Summer 2021 Mitglied von York University, Team S2-G27, Melo-Thaiss Summer 2021
YORK-MELO-THAISS-SU21S2G27
1 Mitglied
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 21
Letzte 30 Tage: 89
Insgesamt: 2,003
