Zum Hauptinhalt wechseln
Replacing a Sprinkler Extension
Was du brauchst
  1. Replacing a Sprinkler Extension, Sprinkler Extension: Schritt 1, Bild 1 von 1
    • Dig a one foot wide hole around the broken sprinkler extension down to the pipe fitting.
    • The pipe fitting is usually about one foot underground.
  2. Replacing a Sprinkler Extension: Schritt 2, Bild 1 von 1
    • Dig around the pipe fitting with a trowel to provide clear access.
  3. Replacing a Sprinkler Extension: Schritt 3, Bild 1 von 1
    • Clean the area around the fitting with water until the fitting is mostly free of dirt.
  4. Replacing a Sprinkler Extension: Schritt 4, Bild 1 von 2 Replacing a Sprinkler Extension: Schritt 4, Bild 2 von 2
    • Unscrew the sprinkler extension from the pipe fitting.
    • Once the extension is removed, water may come out of the open pipe fitting.
  5. Replacing a Sprinkler Extension: Schritt 5, Bild 1 von 1
    • Screw the new sprinkler extension in securely.
  6. Replacing a Sprinkler Extension: Schritt 6, Bild 1 von 2 Replacing a Sprinkler Extension: Schritt 6, Bild 2 von 2
    • Test the sprinkler to ensure that there are no leaks.
    • Refill the hole tightly.
Abschluss
If you have completed the steps successfully you should have a fully functioning sprinkler extension.
Abagayle Serreyn
111 Reputation
1 Anleitung geschrieben
Sam Houston State, Team 16-5, Nardone Fall 2015 Mitglied von Sam Houston State, Team 16-5, Nardone Fall 2015
SHSU-NARDONE-F15S16G5
5 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 824
