Zum Hauptinhalt wechseln
SHARP EL-546XT Battery Replacement
Was du brauchst
  1. SHARP EL-546XT Battery Replacement, Battery: Schritt 1, Bild 1 von 2 SHARP EL-546XT Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Place the calculator on a clean workspace with the back facing up.
  2. SHARP EL-546XT Battery Replacement: Schritt 2, Bild 1 von 3 SHARP EL-546XT Battery Replacement: Schritt 2, Bild 2 von 3 SHARP EL-546XT Battery Replacement: Schritt 2, Bild 3 von 3
    • Remove the calculator cover if you had it on.
    • Turn off the calculator using the 2nd F button then clicking the ON button.
  3. SHARP EL-546XT Battery Replacement: Schritt 3, Bild 1 von 3 SHARP EL-546XT Battery Replacement: Schritt 3, Bild 2 von 3 SHARP EL-546XT Battery Replacement: Schritt 3, Bild 3 von 3
    • Put the calculator cover back on to ensure you don't accidentally press any buttons.
    • Remove the screws from the battery door.
    • Do not remove the other screws as they are not for the battery compartment.
  4. SHARP EL-546XT Battery Replacement: Schritt 4, Bild 1 von 2 SHARP EL-546XT Battery Replacement: Schritt 4, Bild 2 von 2
    • Remove the battery door from the calculator.
  5. SHARP EL-546XT Battery Replacement: Schritt 5, Bild 1 von 3 SHARP EL-546XT Battery Replacement: Schritt 5, Bild 2 von 3 SHARP EL-546XT Battery Replacement: Schritt 5, Bild 3 von 3
    • Use a spudger to gently push the coin battery out through the small hole located below the battery.
    • Be careful not to apply too much force when pushing the old battery out to avoid damaging the calculator or the battery compartment.
  6. SHARP EL-546XT Battery Replacement: Schritt 6, Bild 1 von 3 SHARP EL-546XT Battery Replacement: Schritt 6, Bild 2 von 3 SHARP EL-546XT Battery Replacement: Schritt 6, Bild 3 von 3
    • Gently insert the new battery into the battery compartment.
    • Handle the new batteries with care.
  7. SHARP EL-546XT Battery Replacement: Schritt 7, Bild 1 von 2 SHARP EL-546XT Battery Replacement: Schritt 7, Bild 2 von 2
    • Ensure the battery is properly slotted in the battery compartment.
    • Close the battery compartment with the battery door.
  8. SHARP EL-546XT Battery Replacement: Schritt 8, Bild 1 von 3 SHARP EL-546XT Battery Replacement: Schritt 8, Bild 2 von 3 SHARP EL-546XT Battery Replacement: Schritt 8, Bild 3 von 3
    • Attach the screws back to the battery door.
  9. SHARP EL-546XT Battery Replacement: Schritt 9, Bild 1 von 3 SHARP EL-546XT Battery Replacement: Schritt 9, Bild 2 von 3 SHARP EL-546XT Battery Replacement: Schritt 9, Bild 3 von 3
    • Take the calculator out of the cover.
    • Turn on the calculator and test if it's functioning.
Ziellinie
Mithunan Sivagnanam
169 Reputation
1 Anleitung geschrieben
York University, Team A-11, Allen Summer 2023 Mitglied von York University, Team A-11, Allen Summer 2023
YORK-ALLEN-SU23SAG11
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 10
Letzte 30 Tage: 35
Insgesamt: 483
