Zum Hauptinhalt wechseln
Samsung Captivate Glide Motherboard Replacement
Was du brauchst
  1. Samsung Captivate Glide Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 3 Samsung Captivate Glide Motherboard Replacement, Motherboard: Schritt 1, Bild 2 von 3 Samsung Captivate Glide Motherboard Replacement, Motherboard: Schritt 1, Bild 3 von 3
    • Remove back cover using fingernail or plastic opening tool. The cover pulls up and off.
  2. Samsung Captivate Glide Motherboard Replacement: Schritt 2, Bild 1 von 2 Samsung Captivate Glide Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Remove battery with plastic opening tool or finger.
  3. Samsung Captivate Glide Motherboard Replacement: Schritt 3, Bild 1 von 2 Samsung Captivate Glide Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Remove the seven screws from backplate using the #00 screwdriver.
  4. Samsung Captivate Glide Motherboard Replacement: Schritt 4, Bild 1 von 3 Samsung Captivate Glide Motherboard Replacement: Schritt 4, Bild 2 von 3 Samsung Captivate Glide Motherboard Replacement: Schritt 4, Bild 3 von 3
    • Remove the back plate using the plastic opening tool.
    • There is a lip on each side, and both must be pried up.
    • You can work your way around the edges after prying the two sides.
  5. Samsung Captivate Glide Motherboard Replacement: Schritt 5, Bild 1 von 2 Samsung Captivate Glide Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Use the plastic opening tool to detach the two tabs connecting the motherboard to the base of the phone.
  6. Samsung Captivate Glide Motherboard Replacement: Schritt 6, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Disconnect the antenna cable from the motherboard using tweezers.
  7. Samsung Captivate Glide Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Remove the single screw connecting the motherboard to the base of the phone by using the #00 Phillips screwdriver.
  8. Samsung Captivate Glide Motherboard Replacement: Schritt 8, Bild 1 von 2 Samsung Captivate Glide Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Lift the motherboard out of the base of the phone.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Nicholas Mira
289 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 5-3, Mcgee Fall 2014 Mitglied von USF Tampa, Team 5-3, Mcgee Fall 2014
USFT-MCGEE-F14S5G3
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 756
