Zum Hauptinhalt wechseln
Samsung Exhibit II 4G Loudspeaker Replacement
Was du brauchst
  1. Samsung Exhibit II 4G Loudspeaker Replacement, Battery: Schritt 1, Bild 1 von 1
    • Insert plastic opening tool under back cover.
    • Apply pressure on tool while using a downward motion to pop off back cover.
  2. Samsung Exhibit II 4G Loudspeaker Replacement: Schritt 2, Bild 1 von 1
    • Insert plastic opening tool under battery.
    • Pry battery out.
  3. Samsung Exhibit II 4G Loudspeaker Replacement, Top Rear Housing Cover: Schritt 3, Bild 1 von 1
    • Pry the top cover upward to remove it from the phone.
  4. Samsung Exhibit II 4G Loudspeaker Replacement: Schritt 4, Bild 1 von 1
    • Remove the top cover.
  5. Samsung Exhibit II 4G Loudspeaker Replacement: Schritt 5, Bild 1 von 2 Samsung Exhibit II 4G Loudspeaker Replacement: Schritt 5, Bild 2 von 2
    • Remove the four 3.8mm Phillips #000 screws securing the top cover to the back assembly.
    • Two screws from top and two screws from back.
  6. Samsung Exhibit II 4G Loudspeaker Replacement: Schritt 6, Bild 1 von 3 Samsung Exhibit II 4G Loudspeaker Replacement: Schritt 6, Bild 2 von 3 Samsung Exhibit II 4G Loudspeaker Replacement: Schritt 6, Bild 3 von 3
    • Insert plastic opening tool under top cover.
    • Using hand slide top cover away from phone.
  7. Samsung Exhibit II 4G Loudspeaker Replacement, Midframe: Schritt 7, Bild 1 von 1
    • Remove the four 3.8mm Phillips #000 screws securing the back assembly to the phone.
  8. Samsung Exhibit II 4G Loudspeaker Replacement: Schritt 8, Bild 1 von 1
    • Insert plastic opening tool between back assembly and phone.
    • Pry the back assembly away from phone.
  9. Samsung Exhibit II 4G Loudspeaker Replacement: Schritt 9, Bild 1 von 1
    • With plastic opening tool continue prying around the edge of the back assembly.
  10. Samsung Exhibit II 4G Loudspeaker Replacement: Schritt 10, Bild 1 von 1
    • Pull back panel assembly away from main body.
  11. Samsung Exhibit II 4G Loudspeaker Replacement, Loudspeaker: Schritt 11, Bild 1 von 3 Samsung Exhibit II 4G Loudspeaker Replacement, Loudspeaker: Schritt 11, Bild 2 von 3 Samsung Exhibit II 4G Loudspeaker Replacement, Loudspeaker: Schritt 11, Bild 3 von 3
    • Position Back Panel Assembly so the internal Loudspeaker unit is facing up.
    • With your index fingers and thumbs, grasp the Back Panel Assembly near the Loudspeaker.
    • Twist your palms inward to apply pressure against your index fingers.
    • The Loudspeaker will easily pop out.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
David R
1.152 Reputation
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 283
