Zum Hauptinhalt wechseln
Samsung Galaxy A7 (2018) Front Camera Replacement
Was du brauchst
Einführungsvideo
  1. Samsung Galaxy A7 (2018) Front Camera Replacement, Reset Camera App: Schritt 1, Bild 1 von 3 Samsung Galaxy A7 (2018) Front Camera Replacement, Reset Camera App: Schritt 1, Bild 2 von 3 Samsung Galaxy A7 (2018) Front Camera Replacement, Reset Camera App: Schritt 1, Bild 3 von 3
    • At the beginning reset the Camera app.
    • To reset the camera app go to "Settings", "Apps", "Camera"
    • Select "Storage", then "Clear cache" and "Clear data".
    • Now "Force stop" the app and test the camera.
  2. Samsung Galaxy A7 (2018) Front Camera Replacement, Factory reset: Schritt 2, Bild 1 von 3 Samsung Galaxy A7 (2018) Front Camera Replacement, Factory reset: Schritt 2, Bild 2 von 3 Samsung Galaxy A7 (2018) Front Camera Replacement, Factory reset: Schritt 2, Bild 3 von 3
    • Now it's time to do Factory reset.
    • backup data
    • Go to "Settings", "General management", "Factory data reset", "Reset" and follow the instruction.
    • Try if camera works
  3. Samsung Galaxy A7 (2018) Front Camera Replacement, Battery cover and Middle frame removal: Schritt 3, Bild 1 von 3 Samsung Galaxy A7 (2018) Front Camera Replacement, Battery cover and Middle frame removal: Schritt 3, Bild 2 von 3 Samsung Galaxy A7 (2018) Front Camera Replacement, Battery cover and Middle frame removal: Schritt 3, Bild 3 von 3
    • Use hot air to warm the device.
    • Use Suction cup and plastic tools to separate the battery cover.
  4. Samsung Galaxy A7 (2018) Front Camera Replacement, Middle frame removal: Schritt 4, Bild 1 von 2 Samsung Galaxy A7 (2018) Front Camera Replacement, Middle frame removal: Schritt 4, Bild 2 von 2
    • Remove the SIM Tray.
    • Use plastic tool to remove the middle frame.
  5. Samsung Galaxy A7 (2018) Front Camera Replacement, Front camera replacement: Schritt 5, Bild 1 von 3 Samsung Galaxy A7 (2018) Front Camera Replacement, Front camera replacement: Schritt 5, Bild 2 von 3 Samsung Galaxy A7 (2018) Front Camera Replacement, Front camera replacement: Schritt 5, Bild 3 von 3
    • Disconnect the battery.
    • Replace the front camera.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
ZFix
191.647 Reputation
330 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
321 Mitglieder
1.500 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 44
Insgesamt: 2,290
