Zum Hauptinhalt wechseln
Samsung Galaxy Amp Prime Battery Replacement
Was du brauchst
  1. Samsung Galaxy Amp Prime Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Samsung Galaxy Amp Prime Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Before beginning this repair, power off your phone and unplug it from the charger.
    • Use a spudger or your fingernails to pry the back case off, starting at the small slit on the side of the phone.
  2. Samsung Galaxy Amp Prime Battery Replacement: Schritt 2, Bild 1 von 3 Samsung Galaxy Amp Prime Battery Replacement: Schritt 2, Bild 2 von 3 Samsung Galaxy Amp Prime Battery Replacement: Schritt 2, Bild 3 von 3
    • Insert a spudger or your fingernail in the small space at the bottom right where the battery sits to remove it from the phone.
  3. Samsung Galaxy Amp Prime Battery Replacement: Schritt 3, Bild 1 von 3 Samsung Galaxy Amp Prime Battery Replacement: Schritt 3, Bild 2 von 3 Samsung Galaxy Amp Prime Battery Replacement: Schritt 3, Bild 3 von 3
    • Align the four gold contacts at the top of the battery with the top of the battery compartment.
    • Slide the replacement battery in so the gold contacts connect with the matching socket.
  4. Samsung Galaxy Amp Prime Battery Replacement: Schritt 4, Bild 1 von 1
    • Replace the back case of the phone.
  5. Samsung Galaxy Amp Prime Battery Replacement: Schritt 5, Bild 1 von 1
    • Finally, charge your phone. Once it's charged, power on your phone.
Abschluss
[deleted]
121 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 28
Letzte 30 Tage: 91
Insgesamt: 701
