Einleitung
A problem you may find with your Samsung Galaxy Core Prime is a scratched camera lens. Instead of buying an entirely new phone you can instead replace the camera. For this guide you will need an iOpening tool, a metal spudger, a Phillips #00 screwdriver, or similarly shaped tools.
Was du brauchst
Turn the smartphone off by using the power button on the right-hand side.
Locate the battery near the bottom of the phone. The battery is square, flat, and is labeled 'SAMSUNG'.
Use a Phillips #00 screw driver to remove all eight 4mm screws from the midframe.
In diesem Schritt verwendetes Werkzeug:iFixit Opening Tool$1.99
Use the iFixit Opening tool to pry off the midframe.
Lift the motherboard from the phone with an iFixit Opening Tool.
In diesem Schritt verwendetes Werkzeug:Metal Spudger$2.99
Turn the Motherboard over and disconnect the ribbon connecting the camera to the Motherboard with an iFixit Metal Spudger.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
